Will Change the Way You Park - 2015 Acura TLX SH-AWD Long-Term Road Test
Edmunds.comEdmunds.com Member, Administrator, Moderator Posts: 10,281
edited August 2015 in Acura
imageWill Change the Way You Park - 2015 Acura TLX SH-AWD Long-Term Road Test
When the driver shuts down the engine in the 2015 Acura TLX, the transmission is put in Park automatically.
  • kirkhilles1kirkhilles1 Member Posts: 863
    I dunno, sounds neat, but given all of the controversy with the ignition push buttons, I'd be scared to death of accidentally pushing the button while driving. That being said, I don't think that pushing a "P" button is the way to park either, so...
  • nomercy346nomercy346 Member Posts: 69
    give me a good ole column shifter I can just yank up till it stops and a key to pull out....
    now, get off my lawn!
  • subatomicsubatomic Member Posts: 140
    I am curious to know how the TLX drives when compared to intended competitors like the 3-Series, A4, C-Class, etc. Does the SH-AWD system contribute to more neutral handling? How does the NVH compare to the competition? Inquiring minds want to know....
    edited August 2015
    Still prefer the old fashioned shifters. My favorite is the ones that only have PRND and a manual mode to the side, no separate 321 selections and no gated shifters. Still not a fan of column mounted shifters but they do work well in trucks by saving lots of space.
  • cracknutcracknut Member Posts: 17
    In my Touareg I regularly turn off the car in neutral so that I can push into inch perfect position in my garage. Probably a rare use case but it's good to have the flexibility. What if the Acura needed to be moved while off? Is there a tow or emergency mode?
  • sharpendsharpend Member Posts: 177
    The Ferrari 458 also has the auto Park feature. Makes it ridiculously easy to drive this car.
  • jorocojajajorocojaja Member Posts: 8
    Our i3 has a little too much shunt if you do not put the vehicle into Park before powering off. I am not so sure not placing cars in P is that great of an idea.
