Rear air suspension is not coming up as was previously and with no problems ever with leaks.
OK the day before air suspension stopped my kid dropped a metal bead down into the car lighter hole and this blew a fuse so I replace but unknowingly my dad mixed them so not sure which fuse # is for that but any way since blown fuse my door locks ,trunk popkeypad entry which when was working when code to unlock it tried but to week lived w that but it still locked and opened trunk and doors not now no pwr locks no pwr trunk no ect. But also all of sudden no air rise in back also but I hear compressor as usual and switched fuses also flipped all relays around please help me quit dragging my butt. Thanks GB.
Answers
Year?
1999 towncar
Thanks for rapid response
I don't know what else to tell you; maybe "fix" the fuses (check any under the hood too) and then "reboot" the car by disconnecting the battery for ten minutes or so.
Some people don't recommend unhooking the battery since the computers will have to relearn your driving habits. Maybe some others will pop-in with suggestions.
Usually we see failing compressor posts with older Town Cars and the frequently recommended fix is to swap out the bags for springs. But your situation is a bit different with the electrical gremlins.
If you decide to unhook the battery, make sure you have any needed codes, like for the radio or keypad if you have one.
