Are you in the market for a new car and having a hard time finding affordable options? A reporter would like to speak with you; please reach out to [email protected] by 2/26 for more details.
2003 Explorer Electrical Issues
So I have a new development in my 2003 Explorer that has me confused. About a week ago I noticed that the door ajar light would remain illuminated and that they radio would continue to play even with the key out of the switch and the door open. Additional the chime that warns you that your headlights are on with the key out no longer chimes meaning that I can walk away with the headlights on and run the battery down. For about two days it also had the curious habit of unlocking itself after I had locked the doors with the button on the door but it would not unlock itself if I used the key in the actual lock mechanism from the outside. That problem disappeared but now the interior light won't come on when you open the door though it will come on manually. As some of these problems seem to be indicative of the car not "knowing" that the door is open (radio playing headlight chime) and some that the door is not closed (the door ajar indicator) and some are just weird (the door unlocking itself), I am wondering if there is some many of ECU that might be the point of intersection for all of these issues or if I am overthinking it entirely.
Any thoughts would be appreciated.
Answers
The second comment has to do with the trouble light seen in the video. Those tools need the cords cut off of them and thrown away. The incandescent bulbs get very hot and are subject to breakage. There have been serious injuries and deaths when working with fuel tanks etc. that come from the light falling and breaking the bulb and that exposes an ignition source to vapors. Fluorescent lamps and especially the new style LEDs provide much better lighting at a fraction of the cost to use and they eliminate the dangers from those old "drop lights".
