Righ Axle seal leaking and new plugs with valve adjustment on 2011 Honda Accord SE CVT 99K miles
1sebringnow
Member Posts: 136
Just went to the dealer for an oil change. The dealer then said I need new spark plugs with a valve adjustment for $439 and a right axle seal replacement for $284.01. Then there is a transmission leak and they estimated $125.00.
I don't see any fluid anywhere and I don't know if these are fair prices or not. I am in unfamiliar territory. I have never had any of these issues with a Honda. Any guidance would be sincerely appreciated.
The "axle seal" leak would be expected to be a transmission fluid leak. Is there more to the story? Are there two leaks? Or were they referring to a CV (constant velocity joint) boot? Is the $125 of that actually a transmission service?
The car only has 99K miles on it and I want to keep it another 5 to 7 years if possible. It really is a great car. What would you do? Thanks again for your insights they are appreciated.
I wouldn't call that a "common problem" just one of those things that can eventually cause trouble.
Tires lasted 20,000 miles maybe and about the same for drum brakes.
I recently looked into an engine that had blown a head gasket after around 250,000. I felt no ridge in the cylinder walls at all.
So, Cardoc what do you attribute this too? Much better oil? Hotter operating temps?
