If you made the switch to a hybrid or EV this year and are happy with the savings you're getting on gas costs, a reporter would like to speak with you. Please reach out to [email protected] by 12/5 for more details.
99 Trooper random misfire
gb20mburggb20mburg Member Posts: 1
edited November 2015 in Isuzu
I have a 99 Isuzu Trooper that I am receiving random misfire codes with I have replaced the intake gaskets as they were leaking check the fuel pressure and check the plugs and coil packs the plugs were very black but I have not changed them yet the airbox sounded very loud I also replace the camshaft sensor as the one who installed it before me bent one of the prongs so it was not connected properly I am leaning towards the catalytic converters being stopped up it's very noisy when you rev the engine loud as in something is rattling inside them my next step is disconnecting them and seeing what happens the car runs fine when at idle does not seem to be missing at all
Answers
  • 93tracker5spd93tracker5spd North East Ohio USAMember Posts: 194
    Hello! Have your coil checked at a good auto electric shop, and I would replace the plug wires. Good luck.
