Transmission woes
kleigh1418kleigh1418 Member Posts: 3
edited December 2015 in Chevrolet
I have a 2006 Chevy Trailblazer with 144000 miles. While trying to pull out at a stop sign the transmission would not shift into gear. The RPMs went up but it did not move at all. I shut the vehicle off and let it sit for a minute, and then it worked fine for another 5 min, until the same thing happened. I had the car towed to my house, as it arrived I got in it and drove it right into its parking spot. all gears worked fine. after parking it i put it in drive and once again the car would not move, just an increase in RPM with no movement. Long story short, after running for a minute the truck will not shift into gear, after letting it sit for a couple minutes (not even enough time to cool down) it works for another minute. It seems like the computer may be cutting it off, to prevent damage, but I don't know why. I have talked to a few people who say they have had the same problem (Trailblazer wont move, after cool down moves again) but mine seems to work again shortly after shutdown. It will shift through all the gears when working including reverse, until it stops. then nothing. Ive never had this problem where as long as its working its fine, but cuts off until you restart car. It will not work immediately after shutting off it does take a few minutes, (5 tops) no where near enough time to cool down, also it goes out right after a minute or two of use not enough time to get hot.. Any help would be greatly appreciated.
  • thecardoc3thecardoc3 Member Posts: 5,747
    Did you check the fluid level and condition?
  • kleigh1418kleigh1418 Member Posts: 3
    Yes
    And it is???
  • rek2007rek2007 Member Posts: 3
    I have a 2007 Trailblazer with 120k KM. I have it always in "auto" and today when I slowed down to make a hard left I felt a strong noise below the truck at the back and another at the front, like if the truck rolls over 2 stones and looses power and stability.
    It looks like when the truck changes gears in "auto" when you reach a hard curve, it is not able to properly synchronize and loud noises come from below the truck. Like if gears or cogs are not assembled or not synchronized.
    I changed to 2h and the truck goes fine. It only happens in "auto". I did not try 4H because I think something similar may happen and I don't want to make more damage to the car.
    Any idea what is happening?
    Thnaks a lot for your comments.
    Rek.
