The Engine Just Shut Off - 2015 Ford Mustang GT Long-Term Road Test
Edmunds.com
Member, Administrator, Moderator Posts: 10,315
The engine in our 2015 Ford Mustang GT just shut off by itself.
1) What happened to the Accessory Power on the vehicle when it shut off? Did it continue to provide power?
2) What about the door lock feature? Did it lock the doors? This could be good or bad depending on whether or not you only have one key fob available.
3) Any messages when you restarted the car?
4) Does this only activate if the car is in "Park?" What if it's a manual transmission car? When does it activate in that case (I'm guessing if it's in 'Neutral' it would)?
I could see someone leaving a car running while they went in somewhere and had a passenger waiting in the vehicle. It might be a pain for the passenger to restart, but shouldn't be too big of an issue.
Even if it's one of those my-music-is-on-my-phone-so-I-have-to-have-it-paired-up-to-listen deals, it should stay paired up even if the ignition is on, engine off...so not sure why the engine would have to be running to do this.
http://money.cnn.com/2015/08/26/autos/keyless-ignition-lawsuit/
There are still safety issues associated not knowing that the will be car shutting down. I can think of many reasons people would to leave car running for more then 10 -15 minutes: helping someone on the side of the road fix a flat in the dark, left your pet/child/elderly mother in car and I am sure there are more.
The only time I want my car shutting down on its own is if it detected high carbon monoxide levels (if car has not moved and it has been leaning out the air/fuel ratio). and in this case why not start honking the horn as a warning first and as a last resort shutdown.
It's also explained in the owner's manual. RTFM.
