DIY Front Brake Job Walkaround - 2007 Dodge Charger SRT8 Long-Term Road Test
Edmunds.com
Our 2007 Dodge Charger SRT8 needed front brakes, so I bought some new Brembo pads and rotors and changed them in my driveway.
1
Also...Never-Seez is mandatory wherever you are. If this freezing of the rotor to the hub happened to a car that has spent its entire life in SoCal, then it can happen anywhere. Also use it between rotor and wheel...same conditions, and here in most cases you are dealing with dissimilar metal interface, too - cast-iron rotors and alloy wheels. And a very small amount on studs/bolts.
Any automotive work that involves jackstands, ramps or lifts should also involve a can of one formulation or other of Never-Seez. If you start working on cars at 18 and keep doing it until 85, $50 will buy all of the stuff you'll ever use.
One other thing is to go in and dress the sliding surfaces of the pad carrier with a file - tougher on these fixed-caliper designs than it is on sliding-caliper, but worth doing - sometimes you get a ridge of corrosion that formed where the back edge of the old backing plate was...then you put the new pads in and the new, thicker pad/backing plate bears on that ridge, and the pads don't want to retract and they end up dragging on the rotor faces.
You could also link to an excellent how-to you guys created awhile ago (unless I missed it somewhere):
http://www.edmunds.com/how-to/how-to-change-your-brake-pads.html
Just because you have an engineering degree, that doesn't mean that you are smarter than, or even have more education than what a technician requires today. There are a lot of people who deserve to be dropped into a shop as a technician, so that they get to find out first hand just where they really stand when out comes to doing this work. Its more than fair to say that their opinions of their abilities are more than just a little inflated.
This is a quote of mine. "Anybody can do brakes...........incorrectly". Can you find any mistakes in Dan's story here? REM. It only takes one error, even if it is later corrected to fail. That's the standard that techs are held to.
Can you imagine trusting an indy mechanic to work on your car when that tech may not have even seen your make and model car for a week, much less have done the repair on a like model that month?
