If you made the switch to a hybrid or EV this year and are happy with the savings you're getting on gas costs, a reporter would like to speak with you. Please reach out to [email protected] by 12/5 for more details.
Can't remove key ( is this an FOB?)
relcorelco Member Posts: 1
edited July 2015 in Chrysler
I don't know what an FOB is, but I suspect my "key" is a FOB to you folks. Frequently when I reach my destination, i can not remove the key. I can restart the engine and sometimes, when I turn it off, I can then remove the key. It may take 5 or 6 attempts before success. Often, I just pull out the little door key and leave the car locked with the key in the ignition. This is only for quick visits.
I am new to this forum and any thoughts will be appreciated.
  • sixpac440sixpac440 Member Posts: 6
    my daughters sebring had the same problem i had to replace ignition switch. wasnt hardto replace advance has two types I bought the one you set tumblers to match your original key cost was about $30
    @relco, check for recalls. Just had one done on my '09 Grand Caravan and they replaced the "fobkits" (aka, keys). Not sure what years are covered or if the T&C is involved, but worth looking. Here's a link to the NHTSA look-up page.
  • gerhartrgerhartr Member Posts: 7
    Inside the ignition key are cylinders and they mite be bad cuz of age
