****Anyone have a 2001 Jimmy that actually starts normally??****
jimmy01yikes
Member Posts: 3
I just bought a 2001 Jimmy with only 21K miles. Now after reading all these threads I am scared to death. It seems like just about every owner has issues with the truck starting up and spend $1000's on potential repairs (fuel pump, coils, sensors, wire harnesses, oil pressure... etc) without permanent solution.
Does anyone out there have a 2001 Jimmy 2dr (non 4X4) that hasn't had any start up problems? Should I just turn around and sell this thing before crap hits the fan? Just looking for some piece of mind. Thanks!!
That said, low miles on an old car isn't necessarily a good thing. If you didn't get a pre-purchase inspection done, now would be a good time to have the Jimmy checked out. The shop can tell you what to expect for needed maintenance and repairs.
I know every used car is a risk but the more I read it seems like spending $1000's in repairs on this model is a very high probability. So I was just hoping to hear from a few owners with good experiences.
The best you can do is budget, and plan for the vehicle expenses when they do occur. Then, save what you don't actually spend for the day that a major expense does occur, or until the day that replacing your present car makes the most sense.
It helps if you have a relationship with a mechanic. It sounds like you are happy with the dealer so that's fine. If you don't have a indy shop and don't want to use the dealer in the future, this would be a good time to find one. A good going-over could give you a road map of potential issues to address and should help you decide whether to keep it. Otherwise, just rely on the inspection and maybe spot check a couple of items.
And like Doc says, an $800 brake job or a new throttle body or fuel pump is still just three or four car payments.
