1. B/F Goodrich Traction T/A - $430 OTD
2. Bridgestone Insignia SE 200 - $360 OTD
3. Bridgestone Potenza G009 - $410 OTD
4. Bridgestone Turanza LS-H - $480 OTD
5. Firestone FR440 - $330 OTD
6. Goodyear Assurance TripleTred - $510 OTD
7. Kelly Charger TR (Performance) - $410 OTD
8. Kumho Power Star 732 Touring - $260 OTD
9. Michelin HydroEdge - $560 OTD
10. Toyo Spectrum - $380 OTD
These tires above range from 50,000-90,000 miles, and are quotes from various places. The Michelin HydroEdge is supposed to the "best". I am looking for tires that handle well, and perform well in rain and snow (although I don't drive really fast in these conditions). However, I don't want to feel like I spent too much. I have considered the Kumho, because of low price and the fact that Tire Discounters (where they are sold) provides FREE 4-wheel alignment. The Kelly Charger TR and Michelin HydroEdge also come from Tire Discounters w/free 4-wheel alignment.
I have considered Bridgestone for the fact that I loved the Insignia SL tires on my 2nd former car, a 2000 Toyota Corolla, also the dealer usually haggles on price. The Toyo and the Goodyear come from a place where I have had lots of car repair done and have consistenly performed wonderfully on my cars.
Or, are there any other tires y'all recommend? I can also go to Tirerack.com and order, but I want some personal opinion.
- Alex
Is this just a normal thing? Or is something wrong? The tranny operates perfectly, although I do intend on getting a tranny service done since the car has 63,200 miles on it.
- Alex
Only front end issue I have had on my 2000 Taurus was the sway bar links went out just before the end of the warranty, however I only have about 46K on mine.
As far as replacement tires, I've had my eye on Goodrich Traction TA's also. Seems they have had good reviews at TireRack and are somewhat reasonably priced. I will run the OEM Continentals until next fall so I start nest winter with fresh rubber. The Conti's still have a fair amount of tread left, but their snow performance is starting to deteriorate, and they never have had good wet road traction. Michelin generally builds good tires, but you pay a lot as well.
I haven't noticed and significant banging into gear, then I rarely parallel park on a hill.
Of course, I am more of a Firestone/Bridgestone person. I would not give you a plugged nickle for Goodyears, due to multiple bad experiences with the Eagle LS tires (2 full sets in 35K, both sets seperated the belts).
as far as the trans service, there is a pan drop and filter&fluid change for around $50-$75. there is also a full flush service for around $100-$150. The second service is wiser if you haven't had the fluid changed at all, as it removes all the old fluid. Not all shops have the flush machine, so you may end up going to a dealer or a lubie.
Also, I should've gone into detail in what I am looking for in a tire: excellent handling AND ride; mileage not a huge factor, but having those lovely Michelins with 90,000 mile treadlife is really interesting. Also, I misquoted the TripleTred, they are actually going to cost $580.
If I stay local, there is a place in town where I work that always picks up your car for you (free) and performs the service, then drops it off. This is very handy for me on mornings at work when I DON'T deliver. However, they sell Cooper tires. Are Cooper tires good? I can get a 70,000 mile tire for $73 a piece (about $310 OTD). They can order the Michelin Hydroedge and it would cost me $560 OTD, however, they cannot offer roadside assistance or free repair, because it is a special-ordered item, whereas on their in-stock tires, they will repair any problem free. So, have any of you had positive experience with Cooper?
I greatly appreciate everyone's help!
Fords use barrier hoses to reduce moisture contamination of the brake fluid. Clamping a hose will probably damage it internally.
The car's received its standard fluid and filter replacements over the years. Also any recommendations on good internet parts sites would be appreciated?
Like your doing, just change all of the fluids every two years or 30K.
I would check the simple (and more probable) things first. My guess is that it is one of the rotating assemblies attached to the motor. In other words maybe the bearing in the water pump/alternator/smog pump/AC/power steering pump is going and is the cause of your chirp. The fact that it goes up with acceleration is the best indicator.
As the bearing wears more, the noise will become more and more obvious.
The cheap fix is just to turn the radio up !
I have a 96 Taurus GL, a couple of days ago the "check engine" light came on and they hooked up the computer thingy (can you tell I am not a techie when it comes to cars) and found out that the code was for the Cam Shaft Sensor.
Can anyone tell me what this thing does, will it affect my car if I drive it and any idea as to what it is going to cost to get this thing fixed???
I haven't driven it since and wanted to find out some information online first before I go ahead with any sort of a fix.
Any HELP would be fantastic!!!!
Thanks...
Deniser
One of these days I'll learn to read
Tara in FL
You need to have a pro look at your car and make an evaluation. Yes it could be struts or ball joints tie-rods etc. After they take a look then you can decide whether or not to invest much in your car since the car is not worth much (other than to you).
The squeeling that you hear when you turn may be due to a lack of power steering fluid. Check the power steering fluid reservoir to make sure that it is full. If it is not full then you may have a leak in the power steering system (hoses, pump, rack and pinion ?) that may need to be fixed. The cheap fix is just to keep adding fluid.
I had the EXACT problem and my battery would always go dead if i did not remove the dome and floor lights.
FIX:
Go out and buy a can of WD40. Open each door, one at a time and spray the *@%$ out of the latch that catches when you close the door. Now shut and reopen the door a few times to loosed up and clean everything on the llatch and respray. Do each door one at a time until the dash light goes out.
GOOD LUCK
Started middle of winter, cold engine.
Start car, run for about 30 seconds... 2 large chirps and engine dies. Any running accessories continued to run just fine.
Needed to CRANK and CRANK and CRANK, but it would finally refire then run just fine the rest of the day.
Car would continue to chirp for about 10-15 minutes (lightly, kinda like the sound a bad throwout bearing makes), then the noise would go away.
This happened about 10 times total through the winter.
Things ran great for last 2 weeks.
Today (48deg this morning) car started and ran great.
Went out to go to lunch (67 deg), car turned over, started, ran for 2 seconds and died. Crank crank crank, no start... uh oh... crank crank crank run for 2 seconds died again. This went on for another 8 tries. Finally when I heard it just start to run, I FLOORED the accelerator, and by keeping the RPMs up I was able to get it to keep running. (VERY RICH gas smell) Something in the engine continued chirping like mad. After running for about 15 minutes, the chirp subsided (still there, but very quiet).
Any ideas?
My thoughts are fuel pump, or some sort of temperature sensor.
When the car was in for service before winter, the mechanic wanted to replace the MAF, I told him I'd clean it instead (and I did, and things were fine, yes I know the proper method from years and years of mustang work).
Am open to ideas... fire away!
My father-in-law works at a Ford dealership (unfortunately he is over 3 hours away), and told us before our last problem that there was a T-strap that had to be installed in order to prevent the heater core from going out. The dealership here said that did that on the last two cores. Looking back through our paperwork it doesn't mention anything about it. I wonder if they are actually doing it. They also tested the system for electrolysis and only read .080 volts.
I have noticed from reading this board that several people have commented about heater core problems on the 1996 and 1997 models, but is their also known issues with the 1999 model as well?
I'm seriously considering taking it to another dealer, but would prefer for this dealer to actually fix this problem if I can get them to do it for free, since they haven't actually fixed the problem I paid them to fix back in 2003.
Please help.
Otherwise, I suppose it just could be a short on some component on wherever one of the chime circuit boards is and you are getting occasional intermittent unintended 12V power applied to the chime.
Why would a failed sensor cause noise. Does the cam sensor have moving parts.
We will also post this on SHOtimes to see if we can hit find suggestions over there.
Stanton
