Removing thermostat
nascarbumb
Member Posts: 2
What does it do if you take it out and leave it out for awhile? 1997 grand prix 3.8
Assuming your engine is overheating, and any number of things could be causing that. Removing the thermostat will only mask those. Could be a blown head gasket, cracked cylinder head, thermostat stuck in the shut position, clogged radiator, bad cooling fan.
Probably should have the system pressure tested.
