Removing thermostat
nascarbumbnascarbumb Member Posts: 2
edited January 2016 in Pontiac
What does it do if you take it out and leave it out for awhile? 1997 grand prix 3.8
  • cmhj2000cmhj2000 Member Posts: 381
    engine runs colder
    Probably not a good idea. The engine will run over cool and the coolant temp sensor will think the engine is not up to operating temperature. You'll use more fuel.
    Assuming your engine is overheating, and any number of things could be causing that. Removing the thermostat will only mask those. Could be a blown head gasket, cracked cylinder head, thermostat stuck in the shut position, clogged radiator, bad cooling fan.
    Probably should have the system pressure tested.
