Gearbox
NoTiNGeM
Member Posts: 3
Hello. I have problem for Land Rover Freelander 2002 v6. It only works with reverse gear. If i remove all gearbox electricity then it works with only 4th gear doesn't matter if i turn it in 1st or 2nd gear still it is moving with 4th gear. when i turn gear to D electricity disappear at Reduction time solenoid in 2-3 seconds. Look up solenoid has very little electricity. Diagnostic shows only P0102, P174 and P177 code. Can you explain what's reason or how do i start searching the problem or whom do i contact for these problems? thanks in advance.
Of course, you could start with examining the wiring harness to the transmission for any obvious breaks, damage or corrosion.
Also check fluid levels
I located techs in three cities there. https://iatn.net/directory/georgia One of them might be able to help you.
