Visitor Agreement.
I think catching up on car payments is great, but, it just prolongs the need for a newer car sometime down the road. It may even make it harder to come up with the difference!
I am thinking they could ship them to countries with lax pollution laws....maybe even come out ahead. Kind of like when they turned new Coke into a big win when people demanded their Old Coke back again, and Coke Classic did better than ever.
I need some help if you can answer this one;
The warning light for air pressure came on, and I filled the tires as stated, 38 lbs front, 44 rear.
I just don't know the steps to get the warning to go off. The warning light still comes on when I start the car. It mentions resetting and you can put in a new level for the warning. Should I set the warning to about 2 pounds less?
Next, go to tire pressure on your settings menu using steering wheel controls (the one that shows in you speedometer menu area). Once pressures show up, press the OK button. It will bring up a prompt - reset tire pressure YES NO. Press the YES. That will reset the values.
Also, once it warms up in a day or two, your air pressures will jump to near 50 lbs, way too high, driver.
WOW, that was fast service. I will try that right after dinner. Should the engine be going?
The pressure sounded high to me, but, that is what was printed on the door.
I'll let you know how I do.....Thanx.
Using US....I stopped at a Circle K. I did 3 tires for $1, then it ran out and spent another buck for 1 tire....what happened to the good old days....free air.
255/35ZR19 and 285/30ZR19.
I do think stick is right...you may have had different tires on your E400 Mike.
I think mine are the same size, but I will check.
OF....if MB says rear tires have different pressure they no what they are doing -there will be a reason for it.
Then after putting things back in place in the hallways that had been moved, we headed for Chick Fil A and on to a car dealer to see about a slightly used Cruze that I liked. Negotiated a deal for it. Salesman must get a bonus for delivering the same day..., talked us into waiting on it. At 4:30 we headed home in a slightly used 2LT Cruze 2015 for our son to replace his Cobalt he had driven since high school.
Great car. Peppy.
Today I investigated the rattle in the front of the Cobalt at low speeds on manhole covers. I found the axle's CV inner joint seems worn. So it's off to the dealer for a replacement. I hope it's covered under the extended warranty I had bought! No wonder Imid Jr said the new Cruze was really 'quiet' compared to the Cobalt. I hadn't driven the Cobalt for quite a while and I should have taken it for an extended drive. I assumed he would notice anything that wasn't quite right. LOL.
2018 430i Gran Coupe
I would reset your tire pressure monitors as I explained, but tomorrow, have the dealer check pressures. I still say that 38/44 is way too high, driver.
Thinking about taking a trip from Vancouver to Jasper and then Edmonton, or reverse. The alternative is stay in the US and take Amtrak to Glacier, so far much cheaper. Canada looks really expensive there, even after the CAD crash. Can only imagine how bad it was when USD/CAD was 1.2, not 0.7. Alberta/BC prices look high even now. I'm set on going to that part and seing those mountains and glaciers in June/July.
I was amazing how hard it was to keep from speeding in the Cruze. It is really nice driving.
Imid Jr now has a car to last for several years after we purchase a bumper-to-bumper extended warranty for it. And he has instructions on replacing it in the future in the event I'm not around to guide him. He's not into cars other than whether they run nicely or not, LOL. He was planning to purchase in a couple years after more pay raises and time in his Cobalt but I was ready to replace the leSabre.
I traded the Buick while it was running well although with 210 K miles. It owed me nothing. I always have liked the Cobalt. I'll get it fixed up as much as I can after the OSU college parking bruises to the plastic bumpers and probably sell it myself to a new driver and replace it with a new '17 or '18 Malibu or Cruze.
I have to keep my wife away from the Buick Encore because she will want one of those especially since her long time friend is leasing one in a few months when she turns in her Equinox lease.
Imid...you've been busy keeping the economy humming, congrats on the new Cruze (that is another car that always passes me on the highway) and the new appliances.
Mike....got the air pressure done thanks to your very clear instructions. I checked and rear tires are same as fronts...but recommended pressure in the gas filler door are 36 front 38 back. I suppose things like the gas tank might make a difference in weight. It is possible the monitor would not go back to normal was one tire was way under filled....at 32, so it might not be within parometers.
A good digital tire pressure gauge was a huge help. I think the air pump at Circle K was really off.....those pumps aren't that great and take a lot of abuse.
Closest MB dealer would be about 40 minutes away...so glad you gave me those instructions. Tires are set now and gauge is working....thanks again.
Ford dealer did the same for me. Almost desperate to make delivery the same day. Maybe they fear you'll back out if you leave. Took my guy about 3 hours for registration and financing.
Always look at the inside of the fuel filler door for correct tire pressures.
That's kind of what I thought. So does that apply to all cars? I can see it being a positive tendency in a performance car. I've read that most cars are tuned to oversteer because the average driver can't handle under steer.
Or is it the other way around?
This car I bought has 20K and the tires look brand new--Continental ContiPro which are on the 2LTs instead of Firestones. It has 2 year oil change and rotation plan just like a new GM purchase has. It has an extended CPO bumper-to-bumper warranty to 4 years or 48K miles, which we will extend with an online purchase of a GMEP warranty just like I did for my '14 Malibu. Car is a 2LT model with heated leather seats, color MyLink screen, remote start and some other features which I believe include an acoustic package over the commonly available 1LT.
Imid Jr had looked at these 2LT Cruzes cars at a dealer close to his work location with me that was open on Sunday after he came back from Columbus. They had a large number of fleet cars too but miles tended to be high 20's and son didn't like the tan leather interior on the one in the color he wanted. Monday I went for this one that I had looked at on Sunday at another dealer while dealer was closed.
Never before have I made a car purchase within a week from decided to start looking.
Ironically, the check engine light came on second night Imid Jr had the car. The gas tank was down to 3/4 and car was restarted lukewarm when son went to Kroger and the car ran an emissions leak test--the gas cap probably wasn't tightened properly. I checked the code with my scanner and cleared the light last night.
I haven't been on the train but people who have really love it. I have seen Lake Louise, Jasper, Glaciers and it is magnificent. Vancouver is a beautiful city and try to take the Sky train...it wonders through the city.
Whatever you do, the bit between Thunder Bay and the Rockies isn't especially noteworthy. Rogers Pass (Calgary, Banff) is the more scenic route the rest of the way through the Rockies. I drove my 240-Z and my MGB alongside both rail lines -- good times. Vancouver is one of the most beautiful cities in the world. I should have never left.
Those Mountaineer packages (these are different trains, with domed windows, they travel during the day, include hotels, plus attractions, guides, etc.) are really pricey for a single person. Equivalent of 600-800 US dollars per each day of the trip. 5-day package for 3 to 4 grand, not including tips. I think I can find things for a bit less on my own. Plus, they seem targetted toward AARP crowd, still about 15 years away for me.
Anyway, seems like US side of Glacier may stil be cheaper for an independent type of vacation overall than the Canadian side, albeit it is much smaller and less developed (it may actually be a good thing). Canadian complex of parks, something like five, or more, is enormous, essentially impossible to see even highlights in one visit, even at this exchange. Seems like one could be coming back there for years to see all these different places, from Alberta to British Columbia.
Anyway, still bouncing around with multiple ideas i all different directions. BTW, the craziest one for a train ride I had so far was to take one from Toronto or Winnipeg all the way to Churchill to see polar bears, but perhaps not this time. Completely insane. Over 2 days through tundra each way.
cdnpinhead - would you recommend an MGB that's in good shape for fun in the 2016/and on era?
With all those options it sounds like it wasn't a rental car. Sounds great. Annoying to have lights going on 2 days in.
2013 LX 570 2016 LS 460
Some friends did the Hudson's Bay Tour. They go by train. They had to buy $500 Canada Goose Jackets and other gear because it is -40 degrees there in the summer. There may be organizations that cater to singles...Adventure Tours or something.
If I did get a wild hair and buy a sports car I would have garage space to keep it outta the elements, anyway!
I wonder how many CL curbstoners have used that tool to hide more than loose gas caps.
My Lincoln would throw a CEL for a few seconds about once a month. Never worried about it because a 95' could pass with the whole dash lit up. The computer never stored a code.
It took the enterprising mechanics at my trusted shop to finally diagnose and replace a glitchy cam positioning sensor.
