Vue Died While Driving on Highway
madisonvix
Member Posts: 4
Hi - My 2007 Saturn Vue Hybrid died on Sunday while driving down the highway. The car has 101,500 miles and a brand new (November) battery. It was -5 degrees out at the time. Different engine lights started coming on, one at a time (the check engine light, the traction control light, the oil change light, then the seatbelt light) and then all of a sudden the entire dashboard went dark and the driving lights went out (it was close to sunset so we had the lights on). My fiance barely managed to steer the car over to the shoulder before it completely died. The hazard lights wouldn't even worked. My mechanic got it jump started yesterday and was able to drive it and said no engine lights are on, and everything looks fine. He does not think it was the alternator. Any thoughts on what this could be?
The problem of course is likely to occur again, the things to pay attention to would be the 12v output cable connections from the DC/DC convertor to the 12v power distribution center. The connections between the hybrid controller and the alternator/starter assembly. If none of those show signs of overheating then the diagnostics will hinge on getting the failure to occur again. That often requires re-creating the operating conditions that the problem occurred under. Try and identify details such as how long and/or how far the car was driven when the first symptoms were observed. How far was the car able to be driven before it died completely?What accessories were being used? What were the weather conditions?
This is a low voltage hybrid system (42v) but that's still more than enough potential that it has to be respected and only technicians with hybrid training should be attempting diagnostics and repairs.
I was using a new iphone car charger (plugs into lighter) and audio aux cable that day...both were pretty cheap versions...is it possible that they were lousy and somehow drained the system? That's the only variable that was really different that day, other than the extreme cold.
