Due for 7,500-Mile Service - 2016 Honda Pilot Long-Term Road Test
Edmunds.com
Member, Administrator, Moderator Posts: 10,315
Service is due for our 2016 Honda Pilot. We'll take it in for an oil change and have the broken heated steering wheel looked at.
I would say the oil change should be simple to do yourself, but since you need to have the heated steering wheel checked, you might as well let them change the oil also.
And yeah, while I've heard about no filter oil changes before, my (few) rides always required a new filter.
If the proper oil is used and serviced on time, it should not be getting dark and gelled and the only thing the filter would need to trap would be metallic wear debris, which should be negligible. If someone services this with a conventional product that falls short of protecting the engine correctly, it will in all likelihood still make it out of warranty but long term ownership will see the engine suffer. Do not take oil specification requirements lightly, there are no good, better, best choices here.
2018 VW Passat SE w/tech, 2016 Audi Q5 Premium Plus w/tech, 2006 Acura TL w/nav
