Off-Road Clearance and Suspension Flexibility - 2016 Toyota Tacoma Long-Term Road Test
Edmunds.com
Member, Administrator, Moderator Posts: 10,315
The short trip up our Ramp Travel Index (RTI) ramp showed that the 2016 Toyota Tacoma TRD Off-Road was designed with rough terrain usage in mind.
Any thoughts on that?
That particular photo is of that tire at full stuff, i.e. with that suspension compressed about as far as it will go. If you were to be driving that tire over a rock and stuffing it that far (which happens) as soon as you get over the rock, that tire will rebound, keeping the exhaust up. You also have to consider, that while in that picture it looks like excessive clearance, that exhaust also has to clear the leaf spring when it is at full droop and still maintain room for the exhaust to move around without hitting said spring, which might happen if you were say revving/rocking the truck to get over a difficult obstacle. Move the exhaust much farther back it starts getting in the way of the departure angle.
And while the side exhaust could be vulnerable in a few rare instances, a more zoomed-out view would show that the exhaust tip is tucked up into a somewhat protected corner up above an imaginary line drawn between the tire and the lower edge of the rear bumper. And it is on rubber hangars that permit some movement. Possibly as good as it gets for a factory vehicle that has to comply with certain requirements.
This photo also shows that the factory 31-inch tires could be swapped out for 32-inch tires or possibly even 33-inch tires without rubbing. Possibly.
Twitter: @Edmunds_Test
