Is Cheap Gas Bad for Your Car?
Edmunds.com
Member, Administrator, Moderator Posts: 10,315
Is there much difference in the quality between off-brand cheap gas and gas from well-known companies?
All that glitters is not gold, my friends.
So I stick to the bigger brands when I can, but will also use the less expensive brands when I feel like penny-pinching and then just use a bottle of fuel-system cleaner on occasion to clean up any residue that may have been left behind.
A tip I was told years ago was to rotate through the different gasoline brands because even the additives can build up. Additives from one gasoline will see the additives from another gasoline as build up and remove it. Not sure how true that is...
