Brake Shake - 2015 Acura TLX SH-AWD Long-Term Road Test
Edmunds.com
Member, Administrator, Moderator Posts: 10,315
Our long-term 2015 Acura TLX has covered just 17,000 miles and change, but a bit of brake judder has crept into the driving experience. Warped rotors already? Hopefully it ain't so.
The other things Honda does with brakes is design a funky slide-pin configuration that doesn't slide that well, and also they use these little tiny Philips-head screws to temporarily hold the rotors to the hubs for assembly purposes...they're not needed once the calipers and wheels are attached, but by the time the car is ready for its first brake job, or rotor machining or replacement (see above...), the screws are rusted in place, and the shallow little Philips heads strip out when the tech goes to remove them. Then he is in there with a drill bit, and a bolt extractor, etc. trying to get the rotor off.
The Honda techs I know just remove these screws the first time the car comes in for a tire rotation, or even at the pre-delivery inspection. They don't want to deal with them later.
You seem to experience drastic shifts in MPGs for the strangest reasons. You said you get 3-4 better MPGs when using higher octane and then you think because of wider tires and heavier rotors you lose 3-4 on the highway?
Does anyone know if that is accurate? Logically it makes sense, but wasn't quite sure.
