2015 Ford F-150 - Edmunds Road Test
Edmunds.com
Member, Administrator, Moderator Posts: 10,315
Yes, it's that time again. The oil change reminder flicked on while I was driving our 2015 Ford F-150 and a quick check of the Engine Information screen showed the oil life down to five percent. I was near an auto parts store and a Ford dealership, so I bought the oil at one and a filter at the other and got to work.
"to avoid getting my hand soaked by the deluge of oil"
gloves? maybe you are old school, but, really, it's ok to wear them. no shame.
"the thick stream did once again strike the stabilizer bar"
i'd wrap the bar in a plastic bag from the grocery store to keep the oil off it.
diy is definitely more fun when you don't have to work so hard to clean up. kind of like the cook doesn't wash the dishes.
This is where full-electric car makers could offer something that Tesla doesn't. Make the batteries easily changeable so that you drive into the "refueling" station, they drop the batteries out the bottom and replace them with fresh ones and you're on your way. They could track your battery usage as they probably already do and you pay a small amount each time you switch out that will eventually pay for a new set of batteries over time if you use their service.
And wow, I agree with you and others in this thread about how oil changes could be approached the same way. That was a real SMH moment -- it's so sensible, why hasn't anybody done this?! Must be the work of the all-powerful JiffyLube lobby...
1. nitrile gloves
2. Form-a-funnel (formafunnel.com)
3. OTC 5911 Drain Plug Pro magnetic drain plug removal (all time low price on amazon at present)
http://www.castrol.com/en_gb/united-kingdom/about-us/news-events/castrol-reinvents-oil-change-nexcel.html
Twitter: @Edmunds_Test
Been using a "Topsider" vacuum tank to change the oil on my E39 BMW for over 10years. With filter access on the top of the engine no need to jack up car or get down on the ground.
~20minutes, $25 worth of Mobil 1 and a $6 filter and I've saved ~$90 over a shop doing it, and barely get my hands dirty.
The worst part of this is the clues were everywhere. The base API specs of that time SM and GF4 didn't have a long life designation and were not suitable for extended use, which is what you had with cars like the Terrain that had the maintenance reminder systems. For most people when it came to choosing a product to use, it was far more likely that they would choose one that fell short of their vehicle's spec than it was for them to get something that actually met the spec. This is part of why GM went to the dexos standard and that made it very easy for the consumer to choose the right product since part of that requirement was that the licensed logo had to show up on the front of the bottle.
Even today just seeing something on the shelf that says "synthetic blend" isn't enough to know if you are choosing the right product for a given vehicle. If this was the Motorcraft product used on the F-150, then of course it would be fine, but if it was another brand then you have to put in a little more effort before you make a choice and read the rest of the label on both sides of the bottle.
If the Motorcraft product wasn't chosen for the service on the F150, did whatever was chosen happen to have dexos approval?
This was taken approximately thirty seconds after the last quart of oil was added.
Here it is as viewed from the front. The oil is already at the full mark, but the oil running onto the dipstick makes that a challenge to confirm.
Dealing with delays in reading fluid levels correctly after filling isn't new.
We could also get a few more volunteers to do the same and see what their results are. They could also do as I did on their next oil change and record just how long it did take to get a valid reading. That BTW occurred about a minute later with my Escape.
My old '99 Quest didn't "burn" oil and it was really unusual if the dipstick changed from being checked cold in the garage to getting gas an hour later.
It all seems rather imprecise. And a readout on your dash could track the level over time as well, for those interested in such things.
R&R out of warranty will be the usual exorbitant expense, but some guy will post a YouTube so that most of us will be able to plug and play for $4.75.
Follow the money. And follow the owner's manual.
Not much different from the engine ads. That thing got a Hemi? That's a trademark, not an accurate description of a combustion chamber currently in use today. Got an EcoBoost? Have fun finding oil at Walmart in the 40 foot long aisle of choices if you want to change your oil. Take it to your mechanic? How do you know the shop is using the correct oil, absent doing an analysis afterward.
