Serious issues with 2014 Highlander Trailer Arm repair under warranty
mahighlander
Member Posts: 3
Bought a 2014 Highlander Limited in July 2014. By November 2014, it developed a creaking noise from the rear over significant road bumps when the rear end dips.
Short overview of actions since then: Dealer A researched the problem and after multiple visits, in March 2015, replaced the Trailer Arm as part of a service bulletin recommendation. It doesn’t fix the noise. We're told the noise is a nuisance but not unsafe.
Fast forward a full year, we bring the car for regular service to a new dealership and mention the noise. After a road test and inspection, Dealer B notices the Trailer Arm bold is loose and attempts to tighten. It won’t tighten. Dealer B proceeds to remove the bolt, and long story short, they say the bolt was cross-threaded and is now stripped, and now they can’t reattach the Trailer Arm. Dealer B blames Dealer A workmanship, saying the car is unsafe and undriveable with the Trailer Arm attached by only one bolt, and after consulting with Toyota field technicians and engineers, says the car can’t be repaired without extensive body shop work to replace the lower frame assembly.
Toyota Corp. says the work is not covered under warranty due to it potentially being a problem caused by Dealer A’s workmanship. Dealer B also not taking responsibility for removing the bolt and “causing” the immediate damage. We are stuck between Toyota Corp., Dealer A, and Dealer B, and are paying for a rental out of pocket AND awaiting a big repair estimate which will also have to be paid out of pocket.
None of this seems right or fair. Any suggestions?
I would hope Toyota would jump in on this and they might have if there was no dealer A, and Dealer B just removed a stripped out bolt as it came from the factory. Having Dealer A in the mix kind of messed that opportunity up, seems to me. So Dealer A let Toyota off the hook, and Dealer B doesn't want to be on the hook.
Point is, you are an "aggrieved" party--you suffered damages.
Be sure that you ask Dealer A right up front to "make this right" and be sure you record the date and time of his refusal, and the name of the person who refused. This would be important in Small Claims Court.
Also, it's called a "trailing arm", just so you get the terminology correct.
I was going to let Toyota Customer Care (who opened a case) be the go-between the 2 dealers now, as I was not inclined to go back and confront Dealer A with Dealer B's "accusation." (Dealer B is pointing the finger squarely at Dealer A and is not holding back, with me or with Toyota. And Dealer B says they have documentation to share with me, absolving themselves.)
However, your recommendation to both get the photos and go directly back to Dealer A with the "make it right" offer is making me rethink that...
Thank you again, this is such helpful advice.
I'm not attempting to demonize Dealer A--they may end up doing the right thing. I'm sure they'd like to blame Toyota and have the factory pay for it---who knows?
But you have to stay on top of this so that it doesn't drag on and on. Dealers tend to put these problems on back-burner unless prodded either by Toyota or you. Be polite but be firm.
