Tracker sluggish and backfires
1990 Tracker 1.6L 8v.. Backfires, Sluggish and Hesitates. RPM surge when brake peddle is applied. COde 21, 23. ...Hello everyone. I recently bought a 1990 Tracker cheap. Seems like it wants to run well but has some challenges I dont understand. Ran SeaFoam and fuel cleaner 3 weeks ago. It helped improve the hesitation but seems to have made the backfire worse.
I am about to change plugs, wires, cap. Cant find a vac leak yet but will continue to look. Does anyone have any ideas on what to look for and do before I begin. What else could it be. How do I make my Tracker the best Tracker it can be? BTW, I am not the most mechanically savvy person around but can follow instructions.
Thank you in advance, Have an awesome day!
As for finding vacuum leaks, it might be your brake booster? Have you checked that? You might disconnect the vacuum line to the brake booster and examine it for brake fluid inside, as well as making sure it's got a tight seal to the booster.
And of course, your idea for doing a basic tune up might take care of the problem. Forget additives. You can't fix a problem this bad from a can.
I also completed changing the cap, rotor, wires, plugs. Boy o boy did they need it. (I might post some pics of the plugs, so bad). Afterwords the Tracker had more power and stopped backfiring. Overall felt much better but still room for improvements.
Any suggestions on how to approach this issue from this point?
Thank you for your help
THIS IS GOOD STUFF
