New Lexus Brake Problem--Please Help
                    My 99 Lexus GS 300 has developed what I call a
sand paper or gritty feel in the brake pedal. This
began at about 300 miles and the car now has 1500
on it. Took it to the dealer and of course, they
reported the brakes are "operating properly" Well,
this is true, there is no squeal, noise or
anything like that, and the car stops great. Also
tied in with this is kind of a vibration just in
front of the drivers seat towards the front of the
car. If I put my foot on the floormat I can feel
it. 3 different Lexus techs drove it and said it
is fine. My sister got into it and immediately
said...what's wrong with your brakes. GRRRR. I
know they did not take off the wheel to check the
brake pads but my thoughts as to the cause are as
follows:
1. Slipped or bad brake pad(s)
2. Wheels need balancing
3. Bad or warped rotor
4. Bad wheel bearing
5. Front end out of alignment.
If anybody has any suggestions please post them.
The car is awesome except for this and I want to
get this annoyance fixed. Thanks in advance for
your ideas.
follows:
your ideas.
Now, one thing is not perfectly clear to me from your post: The vibration, is it only happening when you're on the brakes? If not, all your guesses look good and need to be checked out.
For now, assuming vibration only when braking, I think the best guess is a bad rotor. They need to take them off, and check them for true-ness. I don't know how a good mechanic does this. But when there in there, I agree with you that the pads should be taken out and inspected. One could have cracked, like I think you said. And you cannot necessarily inspect them thoroughly without taking them off, despite any impression the mechanic may have given you.
The condition of "glazed rotors" can happen when being overly aggressive with brand new brakes. Not necessarily that you were. It is possible the materials they used on that car are more conducive to causing this. Just for the record, when breaking in new breaks, being gentle is the surest way to try to avoid glazing them. Once they are glazed, heating them up through hard braking (the same thing that causes it!) can burn off the coating on the rotors. But your mechanic did the best thing, as brake cleaner leaves a surface as clean as a baby's...wait, I think I got my phrases mixed up.
$75 for front, rears were $6x can't remember exactly, but the first digit is enough to know when considering these are rotors.
Acura wanted $250 to replace pads and turn the 2 rear rotors! After buying all four rotors, all pads, and tools for the job, I spent $300 for all new brakes with homemade labor(thank you best friend) .
Now let's hope this is the end of warranty work. To summarize. Bought the car May 16th and have had the following done:
1. Glove Box squeak fixed. Re-Aligned door.
2. Homelink Transmitter Fail. Replaced Unit
3. CD Changer Went Bad. Replaced Unit
4. Brake pedal and slight floorboard vibration--Not able to duplicate to indicate problem.
I guess these are fairly minor items and every new car I have bought, I have had something wrong and had to have work done.
Still love the car!
guitarzan
Community Leader/Vans Conference
carlady/roving host
