98 Ford Contour Transmission
New advice on shifting problem on 98 Contour at
low speed ~ 20mph "clunks" hard. According to
FORD TECH this is suppose to be normal.... (I guess
if you don't own or drive the car). Something
about the TCM not adjusting fast enough to
accomidate the change in speed. According to
Dealership Mech. there was a problem with the
module in cars made before a certain date and mine
is not one...
Any ideas or suggestions or other assistance is
appreciated.
is not one...
appreciated.
The only thing that 'really' went was
the relay for the engine fan in the front.
However, it's now July 1999 and I've just
had my 30,000 mile service.
The tranny has and still is fine. (touch wood!)
Everything else is fine.
Some nick picks though: The CD player even if
there's no CD in there (and you have the
radio on) will 'think' it's trying to accept
a CD and will whirr-click it's way on and off
until you either
i) put a CD in or
ii) turn the power off.
Annoying but, to me, minor.
The car's MPG is a bit dissapointing though,
I'm only getting 22MPG and I do a lot of
highway driving.
Other than that, I'm pretty happy with my
purchase.
Gerry
(new york)
Also, do you have good repoir with your salesman? Take him on a drive, and ask him if that would be acceptable for HIS new car.
Always be nice to them, you'll get further. Unless they don't care for nice people.
Although I was quite unsatisfied with the 4cyl ATX drivetrain, I really liked the car. I bought a 6cyl MTX Contour in 1998 and the experience is completely different. I actually think the 96 Mystique rental had slightly better road feel (near perfect ride/handling trade-off), but this platform needed a few more horses under the hood (or, at least, accessible horses - 4cyl MTX is probably quite acceptable). The Duratec and Zetec are very Japanese-like: they truly need to rev, so it's worth learning MTX to have fun with this car (that's exactly what I did.)
Having said that, I love driving it it's a car that like to run. But,if Honda Accord V6 came with a stick I would have bought it.
Hope these help.
gus
Conference Host
End of story.
Contours can become smelly for a number of reasons. The first thing to check is the cabin air filter. If it is dirty it can stink up the inside of the car. Second, the ventilation system has a tendency to grow mold in some climates and can be eliminated by any Ford dealership. If you have a 95 model Contour, the evaporator can leak on to the passenger side floorboard. My 95 SE V6 manual Contour has 82000 miles and has run very well, better than I expected. I did have a few TSB's taken care of under warranty, but other than that my car has been great. Later, Wes.
My 96, v6 Contour has 45k miles and I love driving it. Fastest, and most stable that I've ever had (not saying much since I had an old Saab and a Dodge Caravan.) I've turned in to a kid again. It's great fun accelerating onto and on the freeway... makes it real easy to get away from people. I don't think I would put up with the eccentricities without the Duratec V6. I would like to try the 5 speed with this engine. Would also like to know more about the "the downstream modules
for the computer and change the intake to a
free-flow and the V6 will develop about 30 more HP". Anyone else know anything about this. I assume this is what they do to the SVT engine.
BUT, my auto trans does clunk, especially when accelerating hard and the CD does go bonkers on occasion. Trans clunk is annoying if I let it be.
After reading this discussion, I think I will purchase extended warranty insurance. The $1000 sounds like it will pay off.
New front rotors.
new rear wheel bearings.
belt shielding for the belt squealing in wet weather
Wheel wells separating from the body-referred to the ford body shop.
The remaining problem is the car stalls whenever it is started in temps below 60F. runs for about 10 seconds then idles down and stalls. If you give it some gas it'll keep running but sputter if you pull away lurching like when you first learn to drive a manual. Dealer looked at it, tried reprogramming the computer although they said it didn't stall for them. Pick up the car and it stalls again in the lot. This is a big problem in upstate New York.
Any ideas for a fix?
Always buy american but this car is giving me second thoughts.
Dom
NY
Have the dealer check the idle air control valve on your Contour. This could be responsible for your stalling. Hope this helps, Wes.
Anyhow, I have the 'hang' problem during acceleration - any ideas on how to fix this? I've seen a web page for the SVT with a home-grown fix, but would like to know if this works on the plain-jane V6 Duratec.
also, the hanging during acceleration is being recalled, i belive. we have a 98 contour svt which rpm's hung, and it was a sensor that wasn't working correctly. good luck
PS- I belive that is the site.... its something like that,,,
The only "problems" have been -
1) Yes, sometimes the CD wants to play when there is no CD inserted.
2) The Service Engine light starts going on and off after running about 45 mins [but it has been doing that since about 60K miles:)]
3) There is an intermittent "rubbing" noise under hard right hand cornering.
NO other problems... the car has been trouble free.
Al
Guess what, Ford thinks they should replace the rack&pinion steering unit. I am reluctant to do this partly becayse I'm concerned that somehow more things may get messed up by the repair than get fixed.
I wish I could be right there with the mechanic when the 'operation' begins, know what i mean...?
Have either of you had service performed on the steering unit? If so, then kindly tell us what was result?....
You can get an idea of the problems people have with the Contour. I own one and love it, but like EVERY car made, it has some "issues"
Please try to keep in mind that probably the most important aspect of the car buying experience is dealer support. If you don't trust the dealer, don't expect that dealer to give you excellent service.
Finding the car is easy, finding a competent dealer is tough.
Cheers.
TB
My problem is the lack of a competent dealer in my area, not too mention they seem to develop strange problems given their age
