Honda will not start in the sun
                    I have a 93 Accord LX, 2.2 liter, with 170,000
miles on it. On days when it is 90 degrees or above
and the car sits in the sun, the thing will not
start. I have changed the plugs, wires, and
distributor, all are passing a good spark. I also
drained 2 cans of fuel injector cleaner in to the
gas tank the last few fill-ups, and changed the
fuel filter. Any ideas on the next step? Fuel
pump?
pump?
They told me that they had seen alot of 90-93 accords that would not start when the temp got over 90 and the car was left in the sun. This happenned with my 92 sedan. They said to open the hood and inside doors if the car wouldn't start-that it may help. I got the car started and they said the problem is usually the relay switch - don't know what they were talking about but trust them (billed me as r & r efi relay) no problems since -hopes this helps
these service bulletin #'s (from the NHTSA's
website) and see if yours is covered for
replacement.
I seem to recall they warranted the distributor
for X number of miles, and think yours may be over
the limit.
Not sure, but think the distributor gear tended to
wear out...?
Good luck!
Service Bulletin Number: 89-027R
Bulletin Sequence Number: 044
Date of Bulletin: 9107
NHTSA Item Number: SB028211
Make: HONDA
Model: ACCORD
Year: 1991
Component: ELECTRICAL SYSTEM:IGNITION:DISTRIBUTOR
Summary: DISTRIBUTOR REPAIR PROCEDURE-1988 TO 1991
CIVIC AND 1990/91 ACCORDS DG
Service Bulletin Number: 93-035
Bulletin Sequence Number: 043
Date of Bulletin: 9312
NHTSA Item Number: SB035269
Make: HONDA
Model: ACCORD
Year: 1991
Summary: PRODUCT UPDATE ON 1991 ACCORD
DISTRIBUTOR. *TW THE INSTRUMENT CLUSTER FROM MODEL
200 IS NOW BEING INSTALLED ON MODELS 129 AND 140.
*TW
guitarzan
Community Leader/Vans Conference
Gus
Conference Host
guitarzan
gus
Conference Buddy
(And I think you win a special award for using "buddy" and "pals" in the same post!
Keep up the great work, 'tarzan!!
Thanks for the info. I'll check it out with dealer I bought the car from - 8 years ago!
I have been in contact with a guy from hondainfo.com. He says its the main relay?? The part is about $50 bucks.
I'm not sure if he's trying to push parts or what.
But it certainly is cheaper than a new distributor.
Any thoughts on thise new wrinkle to the problem?
Anyone?
Everyone I talk to seems to think it's that part. The weird thing is, there is no pattern to when it happens or under what conditions.
Also, every time I start the car its seems to start differently. Sometimes it kicks right over, other times its cranks a few times then starts. It very odd and frustrating.
I'll try the part!
These are his exact words:
"It takes about 30 mins to install. It is located above the metal box in the left knee area under the dash."
Being that Acuras and Hondas are very similar I suppose it would be affected by high passenger compartment temperature.
guitarzan
Well, I've read all of these posts and have to say that I've never heard of the problem.
But then, I'm in Seattle, where a scorcher in August can hit 85 degrees!
In my experience, you need long-term direct sunshine on the car to reproduce the problem. I have parked in the shade on 100+ degree days and had no problem, but if it's in the sun any length of time (usually over 4 hours) over 80 and it won't start. Seems directly related to high cabin temperature (which is where the master relay is located).
Finally took it to dealer and explained the problem and earlier solutions. They reported that the igniton needed replacing. Had it done and that did the trick.
Interestingly, an independent shop told me they had known of the solution since about 1993.
Hey, and go to any other Honda topic and mention this problem and you will be called a liar.
Your long list of "problems" nobody has heard of before does cause some doubt!
Specific Problem detail:
When my car sits in rainy or wet (heavy morning dew) conditions for a number of hours, it has trouble starting. If it does start, it quickly stalls when put into drive. To get past this, when I can get it to start I let it idle for at least 10 minutes. That seems to warm the car up enough so it drives fine; after which it will startup w/o any problems, at least until the next time it sits in wet conditions. I replaced the distributor 3 months ago, no problems for 2 1/2 months and now its back. Any ideas? Possible same solution - the Main Relay?
dk
I will also be glad to document that my first correspondence with American Honda was just after the 1992 models came out, when the local dealer offered me a trade with a $6000 loss (to me not him).
The Honda Accord is a great car. I happened to have had one with a number of problems. On the freeway, it ran like a charm. The gas mileage was FANTASTIC. It was not me that labeled it a lemon, but my fellow employees who made it the but of many a joke. And in 10 years, not one other person at work (out of about 70) has purchased a Honda. Personally, I find it sad that a company that makes such great cars would refuse to stand by one bad one. And unfortunately, so do my colleagues, who have heard not a wimper or complaint from me in all those years. They just wondered why it didn't run and got tired of picking me up at the shop.
I don't doubt that you have had troubles. It just seems that you may embellish them a bit.
And...I have to wonder what your co-workers are buying since they are now scared of Hondas?
No car is perfect but I suspect that mis-diagnosis of your problems may have been a problem.
As for the co-workers, Toyotas, Nissans, Ford Explorers, Chevy Suburbans and Tahoes, various American luxury sedans, and at last count, 5 Isuzu Rodeos (you have to wonder why they weren't Honda Passports).
Incidentally, the local Honda dealer lost his Jaguar dealership to the dealer that sells Isuzu, supposedly because of poor customer satisfaction. And the recently fired president of the Honda dealership is now suing the owner. Apparently, I ain't the only unhappy party.
So, did I guess the right place?
don't be afraid to name names; you could be helping a lot of people avoid similar situations by doing so.
