Have you recently switched from a gas-powered vehicle to an EV, or vice-versa? A national TV broadcast network would like to speak with you; please reach out to [email protected] by 12/5 for more details.
Are you a current or prospective Tesla customer who is having a change of heart about the brand? A national news reporter would like to speak with you; please reach out to [email protected] by 12/5 for more details.
Need help, Cavalier no start
jwill80jwill80 Member Posts: 1
edited June 2016 in Chevrolet
What can I try to find out what is wrong with my 2005 Chevy cavalier it want make s sound
Answers
  • 93tracker5spd93tracker5spd North East Ohio USAMember Posts: 194
    Hello! First, I assume you have already done the basic: clean both battery cables and posts and retighten. You have checked the battery to make sure it is fully charged. Now, does anything else work, dash indicator lights with key on, radio, dome light, head/tail lights, brake lights, etc., etc. There are many circuits involved with these other items, but when the engine isn't running, they all draw their power from the same source; the battery. If any of these other systems work, and the starter worked fine until it didn't, then check and clean your initial static ground; that is the ground cable from the battery to the frame, be sure the connection to the frame is clean and tight, look for one or more ground straps; (wide woven copper straps), connecting the frame to the chassis, they also must be clean and tight. If this is does not solve the problem will need much more information. Good luck.
