2014 Subaru Forester 2.5I Premium Timing Belt
surgarshack
Member Posts: 3
I am being told by my local Subaru Dealer that I need a timing belt change on my 2014 Subaru Forester 2.5I. I was under the impression that this model has a timing chain so does it have a chain or a belt? Does it need to be changed out at 120,000 miles?
Answers
"An entirely new generation of boxer engine announced on 23 September 2010.[8] By increasing piston stroke and decreasing piston bore, Subaru aimed to reduce emissions and improve fuel economy, while increasing and broadening torque output over the previous generation engine.
The FB has an all new block and head featuring dual overhead cams with intake and exhaust variable valve timing (AVCS - Active Valve Control System), and a timing chain that replaced the timing belt. Moving to chain-driven cams is said to allow the valves to be placed at a more narrow angle to each other and shrink the bore of cylinder from 99.5 mm to 94. It results in less unburned fuel during cold start, thereby reducing emissions. Subaru is able to maintain the exterior dimension substantially unchanged by asymmetrical connecting rods like those in EZ36. The FB is only marginally heavier. Car and Driver is told direct injection will be added soon."
No timing belt is listed by Gates or by Rockauto for the 2014, but is for the 2010.
My sister has had good luck; she's on her second Subaru now. I never really trusted our '97 Outback but we dodged the head gasket problem. Mine only occasionally used a bit of oil.
2014 Legacy/Outback = EJ25 (timing belt), 2015+ = FB25 (timing chain).
As previously mentioned, 2011+ Forester = FB25 (timing chain).
And to continue ...
2014+ Forester XT = FA20T
2012+ Impreza = FB20
BRZ = FA20
