Difficulty starting
I just purchased a used 2007 CTS. So far every time we've filled the car with gas (only 3 times) it won't start. It takes at a minimum of 3 attempts and each attempt is last for a while. It just turns over and over and sounds like it is not getting any gas. Then it finally kicks in.
This only happens when we put gas in it. Otherwise it fires up first time every time.
Could it be filling up with vapors that the engine needs to purge somehow prior to actual fuel getting through?
I presume it goes in the Canister but where is this located?
battery is new,
Also the key would get stuck and not release. ????
