Thanks...
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&cate- gory=33596&item=2458314446
I dont see how this can be true, or if it is true it must be bad for you car. If I could add a few extra hp for $12 i'd do it if it wouldnt damage my car.
I have a 98 jetta gl 5sp
It's a cheap, simple 1/4 watt resistor which plugs into the harness connector for the air intake temp or coolant temp sensor. Makes the engine control computer think the car's running in Antarctica, and over-fuels the engine. Wait till you see your gas mileage afterwards. Then there's the possibility of long term engine damage due to excess fuel washing the cylinder walls, oil dilution......
If you REALLY want to do it yourself... do some more research and with $2 of Radio-shack parts, you can put together somthing better than that silly thing.
If you are REALLY looking for some cheap power. Anyone with the turbocharged engine (TDI or 1.8T) has options that can really improve power with little impact to MPG. (often even BETTER MPG.)
Jeremy
Does it have a hole in it and is leaking?
Is it failing some kind of exhaust sniffer test?
The reason I am curious is because I have many vehicles (mostly VWs) travel over 130K miles with no issues with the cat converter. Everyting else in the exhaust was replaced many times... but the original Cat was never replaced.
I drove the above mentioned Jetta today, but noticed two things:
1. CV-Joints (both sides I think) are in rough shape, and;
2. Gearshift is mushy...doesn't give me that feel-good engage if you know what I mean. Is it a clutch issue?
The dealership wants $2500 for it (137K)......so I'm wondering what to expect for repair costs - Any experience here?
Many years experience tells me that it is not worth the labor to replace just A CV joint or two... the others have the same milage on them and will fail soon. It is a better finantial decesion to just replace each driveshaft. A quick search for driveshafts on the web tells me that they are around $220 each side.
If you choose to have a CV joint replaced... you will pay less for parts but MUCH MORE for labor. It is far easier for a mechanic to just bolt in a fresh driveshaft. Your money is going into PARTS YOU WILL USE instead of the mechanics pocket.
As for the shifting... there is no way to tell how the clutch was treated in its previous life. Personally, I would either leave it alone or select another vehicle.
You may be able to get the shifting feel you expect by having the shift linkage adjusted. There are some plastic "shims" that tend to wear out and for $20 can do wonders to the shifting feel.
I hope this helps you out...
If you have a MIL, get it checked out. It will throw codes indicating that the cat is bad.
Jeremy
I've noticed, very recently, that my car is using gas at a much higher rate than it used to. Normally I could get 28-30 mpg. Now I am looking at 24-27. I drive about 50% highway and 50% city. My commute is 7.7 miles one way.
The only difference would be that I spend time letting the car idle and warm up now that the weather is so cold. But I can't imagine the minute or so I spend warming up the car (just enough to get the tachometer to drop below 1000) would cause such a drop in fuel efficiency.
Has anyone else experienced this?
What could be the cause?
I looked under the hood to see if a hose burst but I saw no sign of leaking. I doubt it is a leak in the fuel tank since I would be leaving fuel puddles. All the fluids are fine otherwise. Oil consumption is negligible/normal. The car is not making any noises at all to hint to some problem. If I wasn't monitoring my fuel economy I would never know there was a problem.
It is not good practice to start a car with fuel injection and let sit and idle only to warm up. It is bad in the long run for the motor. Carburetor equipped engines of the academic times are a different story. Your 7-8 mile commute factors into the lower mileage as the car still has just finished warming up when you get to work and shut it down.
Most new car owner's manuals recommend to start car and drive easily until warmed up. Open your owners book to see.
1. Cognition coil recall
2. Automatic windows malfunction recall
3. Water leak from the release lever for engine hood
4. Engine coolant light on due to circuit problem
5. MIL light on for no specific reason and
6. Fuel gauge goes to half-way after up/down hill and resume usual position only after 10-20 minutes even with tank full
7. Selector lever display will be all highlighted and can't switch gears unless restarting the car
I wondered if anyone has encountered problem #7 and found any reason behind this malfunction. The dealer can't find anything so far.
I used to like my car but now I am a little scared driving it, especially I commute 60 miles everyday on the highway. I wondered if I should exchange for another car if 2002 Jetta 1.8T are really of bad quality.
Thanks for your advice. However, I am well aware of the owner's manual stating that the engine does not need to be warmed up. I don't think that applies to winter driving. I just called my dealership and they told me to let my car warm up first. I don't know anyone who does not let their fuel injected car warm up first since high (a relative term) rpms could cause a lot of problems with cold pistons. In fact, everyone I know, all of my neighbors, friends, co-workers, all let their car warm up first.
Since both of you live in states that are south of me, I think you experience milder winters. I live in central New England and the last two winters have been brutal. I just can't imagine not warming up the car in that kind of weather. I think I would cause more damage if I didn't let it warm up.
I don't know anyone who owns a car with a carborator. I think they are all fuel injected. I have never heard of idling being bad for the engine, but I'm sure it isn't great for the environment.
The one thought that comes to mind is that the gas stations have switched to a winter mixture in the gasoline. That may be making the car less efficient. Does anyone know?
However, I have heard a few Jetta horror stories lately, as in dozens of expensive repairs.
I love the way VWs drive, but not enough to endure so many mechanical problems.
Any advice?
Any advice? "
For the increased chances of getting a "problem child" stay with gasser VW. For less chances I would stick with a Japanese make like a Civic or Corolla. VW gasser engines have too many "problem children" that consume more oil than most.
I have a TDI Jetta and in 10 mo and 23k miles, it has performed flawlessly. But in the worst case, I have done and am prepared to do most maintenance myself and after 50k warranty willing to swap parts as needed.
Letting an engine idle (especially until it is fully up to operating temp) will contaminate the oil with gunk and eventually destroy the engine.
As soon as the engine is running smoothly, DRIVE IT! Just be gentle.
It is a FACT that most engine wear occours DURING WARMUP. It is then, obvious that the warmup time should be made as short as possible. Gentle driving warms up the engine significantly faster than idling it.
You spoke of living in "Central New England" but I cannot find your locale in your profile. I have extensive experience with true cold weather driving. I wonder if you have ever experienced "square tires" from being soo cold/stiff that they have flat spots on them. How about power-steering that will not turn because of the cold? Sublimination from the windshield? Doors that will not close no matter how hard you slam them?
If you are concerned about driving a cold engine, get an engine heater. All of my vehicles have them.
Basically, starting process in sub-zero Farenheit weather is;
*Turn key to 'run' and observe that self-tests pass.
*Turn key to 'start' and pray that the battery has enough juice to crank engine.
...if engine starts....
*After 10-30 seconds let clutch out slowly in neutral to "load" the engine with the gears spinning in the very thick transmission lube.
* Continue to 'load' the engine by tuning on electrical items (lights, seats, rear defrost, heated mirrors.)
*gently turn steering wheel left-right several inches to verify that power-steering fluid is thin enough to steer.
*by now the engine has been idling for about a minute... go ahead and drive it gently. keep revs low and do not overload engine with quick accelleration.
NOTE: Some folks unfortunately have an AUTOMATIC transmission. (Mostly North America has this affliction) If you are one of the 'unfortunates', you may hold the brake and place engine in DRIVE to load it gently for the first 50 seconds or so before starting to drive. This allows time for the automatic xmission fluid to start flowing thru the passages. On a VW, this also heats up the engine because the heat generated in the xmission is transferred to the engine antifreeze via a heat exchanger.
If VW still sold a pickup truck in North America, I would not own a Dodge. (I REALLY LOVED my rabbitt-pickup)
I never considerd any of my VWs a "maint. nightmare". They were maintained propely and things were fixed correctly when problems arised. (broken Muffler, brakes worn out, worn suspension parts...etc) Nothing that any other vehicle with over 100,000 miles may encounter.
My daughters 1st car was an old Golf. She drove the wheels off that thing... and it never left her stranded. Now, being older, she just bought a 2001 Golf and LOVES it.
I have been so impressed with purchasing USED VWs over the years, I bought my wife a NEW one last year. (only 13,000 miles thus far)
Any suggestions on likely steps to take to eliminate the foul odor of exhaust from the cab would be greatly appreciated as would ideas of cars or small SUVS best suited to a growing family.
Jeremy
I have a 99 jetta that I have a tremendous rattle coming from the catalytic converter. It seems like something inside came loose and is bouncing around inside. It is really horrible especially at idle. I thought it was something I had to live with, or spend a lot of money on a new one. A friend said it should be covered under the factory warranty. I have about 90k on the car now. Anyone think I could get this covered? Also, I haven't had the car in for service in quite a while. Any recommendation on what I should get serviced without spending a fortune? Any input would be appreciated. Thanks
Question: I have a little of what appears to be black paint on my left taillight. I can't remove it with a razor. Any suggestions?
I assume you have a NA (Normally Asperated) engine that does not have an intercooler so this is not an issue for you.
Any ideas about that paint on the taillight? ;-)
This website sells Ecode lighting products;
http://www.ecstuning.com/stage/edpd/pagebuild_v2.cgi/?html=learnm- - ore.html&productID=14
http://www.ecstuning.com/stage/edpd/pagebuild_v2.cgi?home=Volkswa- gen
Here is another one;
http://www.momentummotorparts.com/pages/mmpecodes.html
These are not true E-codes lights but are simular
http://www.performance-cafe.com/
The main problem plaguing me right now is extremely odd and puzzling. It started about 2 months ago when we were having record low temperatures here in New England. I had the heater up high and after awhile I started hearing a loud creaking sound coming from what sounded like the center of the dash. Not a rattle, but a creak. If I put my hand on the dash above the center vents it stops. I don't even have to apply any pressure. Also, if I turn the temperature control knob to the coldest setting and blow cold air for about 15-30 seconds it goes away. Usually happens most when the heater control switch is set to either Floor/Vents or Floor setting.
Any thoughts? This one ranks up there with the LCD clock and odometer numbers going wacky on occasion (I know others have seen this one too)
Shift the transmision so it is between N and D and while holding it there start the engine and [non-permissible content removed] to D.
Check the doccumentation with the owners manual. There should be a document explaining the FEDERAL EMMISSIONS WARANTEE. It is often significanty longer than the manufacturers warantee on the test of the vehicle.
