Camry V6. 1994
Hi. A few weeks ago, my Camry 3.0 refused to accelerate from a intersection after stopping for a red. The check engine light was on. Every time I attempted to go, it cut off. Immediately restarted, ran smoothly while at idle. Would not even allow higher rpm' sin neutral. Had it towed home. Didn't go back to car for about a week. Had someone to use diagnostic tool to see what problem was becauseofcheck engine light. No light on,car is running perfectly,no history shown on tool to trouble shoot or get a code. I'm afraid to leave neighborhood not knowing when or where it will rear itsuglyhead again. Any history of this ? I've heard about possibility of one of the two sensors,but not knowing which one or of indeed one or both are bad seems a bit much. Thanks for any insight that you can provide.
Best Answers
Options[Deleted User] Posts: 0Oxygen sensor, mass air flow sensor, or it could be the computer. I would try cheapest first. Also, when is the last time you inspected your intake system? Have you replaced your air filter lately? Also, you may need to run it from park back into drive and make sure the parking sensor is not still engaged. \
Lastly, it is a 94. In 1994, I had a primitive Sprint PCS system phone that only worked in a few cities. No texting, just a LED numeric screen for the phone number. NOBODY CARRIED CELL PHONES YET. That's how old your car is!!!!!! So it is bound to have some gremlins. The only place that is going to be able to fix this is the dealer or a Toyota/Honda shop that has been open for 30+ years. Sorry. It might be time to sell, You will have no trouble doing so......actually, you will be overwhelmed with calls.
Ok, if selling is not an option I would start with the Oxygen sensor and Mass Airflow Sensor. They get covered with goo over time and stop sending the computer the right answers. It will start out intermittently cutting out, revving up and down on its own, and throwing a code. A new o2 sensor is $25 and a MAS is probably nearly the same. Spend $20 bucks on a new air filter while you're at it and you can then see if that solved the problem. It will certainly get cleaner air into the engine and the new sensors will give the computer the right information. What stumps me is why didn't the computer keep the code? Is it time sensitive? Has the computer (ECU) ever been replaced? Because after cheap intake sensors I would be looking for a new ECU. Thats all for now.5 -
Optionsmymo94 Member Posts: 4Thanks everyone. No it wasn't jump started up to that point, but has since. I will start out with the less expensive steps. Wondering if ialsogot a bat computer?5
Answers
From your first response. Seriously? I hope the OP doesn't follow your advice and start shot-gunning parts aimlessly. There isn't a more expensive way to try to fix a car than to start guessing like that. Again, not true. There are a lot of technicians (independents) that can handle this system even without all of the sophistication that they are used to seeing today. Just imagine the time and money you have told the O.P. to waste if the issue turns out to be a fuel pump, ignition coil, cap and rotor (plug wires), or ?????
It took that long because I really don't drive it often ( sentimental holding on, moms car)
Really want to make it trustworthy though.
Runs so damn good e crept for this once. Yes I did have computer changed about 4 months ago. Again don't drive often.
Q
