LIBERTY 2010 DIESEL 139K
Hi never had a issue with my Jeep - today all of a sudden it stoped. No way to start it up again. Any ideas where I can begin checking? Thank you all.
Answers
http://forums.edmunds.com/discussion/3382/jeep/liberty/jeep-liberty-diesel#latest
11000 posts about the Liberty diesel.
From there, what is the low side fuel pressure, what is the high side pressure (both in scan data as well as confirmed by mechanical gage where applicable).
As far as not starting is it cranking? Not cranking? If cranking does it sound normal or faster than normal? Is it trying to fire at all?
Maybe we could just shut it all down, and have one big discussion!
Having worked on a few of these Jeep Diesels I have a pretty good idea of what a laundry list of possible causes is going to do for carmonacr. The odds are actually not in his/her favor to try and just assume something that solved someone else's vehicle problem has anything at all to do with this problem. But really this isn't new and needing to test correctly, which starts with training and the right tools is something that should be stressed each and every time. If the O.P. just browses that forum and starts loading up the parts cannon with guesses from it, they could waste $1K-$2K in a heartbeat. In fact the posts in that thread very likely describe events that this is exactly what happened when someone without the correct approach made a repair attempt.
"Maybe we could just shut it all down, and have one big discussion!"
That depends on what someone wants to try to do with the information. If all they are looking for is a silver bullet answer then the information is being misused. If they want to use it to help figure out how to test and prove if something is causing a give problem, and not just throw parts at it then it's real value is being revealed.
Imagine for the moment that one of the posts actually does describe the O.P's vehicle issue exactly. Which one is the magic one? With the right approach, none of what is there would be required to solve the O.P's Jeep No-Start.
