Volkswagen Jetta Maintenance and Repair
18788909293131
  • evoodooevoodoo Member Posts: 1
    Hey,
    The EPC light on my Jetta, 2001, 2L w/ 100km has just light up. The light has been on consistantly for the last couple of days. I've checked the net for help, but only find articles about EPC lights that switch on and off.
    I want to avoid bringing the car into the dealership, because I've heard stories of them just turning off the light and not necessarily fixing the issue.
    I know that the engine light will turn on if the gas covered isn't tightened securely, so is there any small issue that might be responsible for the epc light?
    PS- I have no problems starting or driving
  • waiwai Member Posts: 325
    I like to install aftermarket performance brake pad like Hawk or EBC street performance on my Jetta, but I search Tire rack web site, those only fit Jetta 1.8T or GTI but not compatible on VR6. Did anybody install any aftermarket high performance brake pad on 04 GLI(VR6)?
  • bpeeblesbpeebles Member Posts: 4,085
    Are you SURE you want "high performance" brake pads? Are you aware that such brake pads dont have much braking power the first few times you use them every day? (they have to be warmed up just to start working) Also, they will tend to leave all kinds of black dust all over your wheels.
    I have first-hand experience with so called "high performance" brake pads. When you REALLY need them - like when a deer is standing on the road in front of you at night - they DO NOT WORK for several revolutions of the wheels.
    Dont get me wrong, if you are planning on racing on a track, then by all means install "high performance" brake pads. Your breaks will be warmed up when you need them under those conditions.
    You may be better off using CERAMIC-based pads. They are better than OEM -- yet do not leave black dust all over your wheels.
    But the $400-800 (and yeah $800 sounds crazy) was probably for the 40K mi service...I think that is the biggest one for VW. That one is $400-450 at the dealer I went to for 10K.
    I think most cars have something in that range at somewhere like 40-60K mi.
    I need some street high performance like Hawk, street performance pad that gives more bite and can resist heat while consistent hard braking, Whats the difference between ceramic and composite material? Anyway my OEM pad has plenty of black dust now.
    The word "composite" means "made up of different materials".... that word could be used to describe almost any brakepad on the market.
    The main difference in pads is usually "organic" or "metallic".... with "ceramic" being more like what is used on racecars. The NAPA "ceramix" is a good example of a ceramic-based pad. So is the Raybestos "QS" pad material.
    Some of the more "agressive" pad materials will wear out your rotors.
    Here is a photo of what 3 vermont winters did to a set of "powerslot" rotors.... they are junk. I now run Bendix or Raybestos rotors with NAPA "ceramix" pads.
    Where can I buy this NAPA ceramix pads? Is VR6's brake size same as your TDI, means they are compatible.
    NAPA auto parts are available from NAPA autoparts stores.
    http://www.napaautocenter.net/
    (National Automobile Parts Associacian)
    As for you VR6 being the same as my Jetta -- I have no clue. Might I suggest you do some internet searches?
    There are many online sites you can do research... A quick 30-second search gave me the following; (HINT: look at the partnumbers to see if YOUR car has same parts as another one.)
    http://www.1stvwparts.com/
    http://www.germanautoparts.com/
    http://www.bestforeignparts.com/
    http://www.volksparts.com/A3.htm
    http://www.autopartsworld.com/volkswagen_parts.html
    http://www.dubautoparts.com/volkswagenrotors.html
    Bpeebles, thank you for your time and help.
  • babyjet1babyjet1 Member Posts: 2
    Here is my problem: 03 jetta 4cyl .... runs great except every few times I stop somewhere it won't start. Sometimes it is really good and no problem... others it has to be jumped 4 or 5 times a day. Can anyone help me figure this out?
    Since you said that it "has to be jumped 4 or 5 times a day." I am assuming that it starts OK when given a healthy supply of 12V power. This suggests that your battery is somehow DISCHARGING while your vehicle it parked.
    Now that we have established what the probable cause of not starting is.... YOU need to ascertain WHY your battery is discharging.
    To help you get started, look for things like the following;
    1) interiour lights left on
    2) Brakelights still on (this has been known to happen on VWs)
    3) Any other electrical components still drawing power while parked.
    Also, verify that the alternator is doing its job of CHARGING the battery.
    PS: If nothhing OBVIOUS is found, then one would have to use current-measuring devices to isolate what is draining the battery.
    SUGGESTION: Fully charge your battery for several hours on a trickle-charger once you find and resolve the problem.
  • jenezrowjenezrow Member Posts: 2
    i'm still having the jolting problem on my '04 jetta. keep us updated when you get your new transmission! thanks!
  • justadrmrjustadrmr Member Posts: 2
    I purchased a used 2000(acutally the plate says 99.5)Jetta TDI. I love(d) it. It has lost power.It got to were it would not accelerate even on flat ground. I have changed the MAF,cleaned the inner cooler,cleaned the egr,new garrett turbo with new intake, cleaned exhaust system and no codes come up on the computer. Now the car will accelerate a litte. You have to get it up to 3k rmps, let off the gas pedal for it to shift and so on. So pulling out into traffic or freeway driving is non existant.The tranny has been check and is working correctly. Now the mechanic is telling MAYBE it's the injection pump. I am really getting sick of this process of elimination game. Does anyone have any ideas? I really do love the car.
    If you do not want to be guessing - try
    VAGCOM
  • aaron6aaron6 Member Posts: 1
    I just had my rear brake pads and front rotors replaced on my 2001 Jetta VR6, when I went to pick up my car the "mechanic" asked me why the window wouldn't roll up, I told him I have no idea because I have never had a problem with the windows rolling up or down. He said he took it for a test drive this morning to test the brakes and he rolled down the window, and now it will not roll up, none of the windows will roll down and the one he rolled down is stuck. He does not know what happened, nor can he fix it. Does anyone know if there could be any kind of link between the brake job and the windows??
  • mpc170mpc170 Member Posts: 1
    Made a sad attempt to change the oil in my 2002 jetta and turned a plug on the bottom (used allen wrench) to empty the bin. Turned out it wasnt the oil pan. The oil pan was to the right (looking up at the chassis from underneath) which I later realized and emptied. But whatever I emptied looked like oil but not exactly sure what it is or how to replace it. Car engine runs but transmission doesnt seem to catch and make car go. I dont think it trans. fluid since its not redish. Any ideas. Appreciate it.
  • dancermandancerman Member Posts: 220
    Well.... how much fluid did you remove? Seems like it has to be transmission fluid if the car doesn't "catch". Did you check the transmission dipstick level? If it is showing no fluid, then pour it back in. Be sure you filter out any dirt that may have gotten mixed in.
    I may have posted too soon...my apologies... apparently the Jetta doesn't have a dipstick for the auto transmission. You will likely need to visit the dealer for service. :cry: Apparently they don't think the consumer has any reason to service the transmission. Unbelieveable.
    They use synthetic trans fluid, supposed to be good for the "life of the vehicle".
    "Apparently they don't think the consumer has any reason to service the transmission"
    I guess if you know what you are doing you can service your own transmission, same as with any other car. :)
  • eguilbeaueguilbeau Member Posts: 1
    the same thing JUST happened to me....it was a faulty brake light switch. When it would act up the brake lights wouldnt work when I pressed on the pedal, but would stay on all night long. It drained my battery and I had to jump it every time I got in it but the battery kept registering 12v. I havent had any problems with it since.
  • jbradford2jbradford2 Member Posts: 2
    I bought my car a year ago. I am the second owner. I purchased an extended warranty -just in case. I have experienced absolutely no problems with it until a month ago.
    The driver tail light switch was recalled because it was faulty causing the auto gear shifter to not function properly. I discovered this only after taking it to the dealership to determine this was the issue, the problem was fixed.
    Four days later the battery needed to be replaced, as it had not been replaced since the original purchase prior. Or so I thought. Prior to replacing the battery, the car just clicked and wouldn't start. Once the battery was replaced, it worked great. I drove it 1200 miles for a family trip over Memorial Day weekend. During which, no issues surfaced.
    Upon driving it home, I turned the car off to unload it. Twenty minutes later I attempted to start the car only to find it clicking and not starting again. After 2 more failed attempts at starting it, and a failed jump, I called triple A.
    The triple A tow truck service arrives and inquires about the issues, tells me the car is hot, and needed to cool, and starts the car promptly. Meanwhile the check engine light turns on and won't turn off.
    I drive the car 10 minutes away. Turn off car, go to start again, won't start. Again, check engine light comes on. For two days the car has had issues starting and the check engine light turns off and on.
    I took my car to Shucks - where I bought the battery - to run some tests. Battery is 7 days old at this point. It is supposed to run at 600 amps and is down to 427 amps. Alternator looks fine, tested fine.
    Here is what's been suggested to me the source of the issue might be; the alternator, the starter, or could be a short caused by the driver taillight issue.
    The dealership tells me they can't get me in until end of next week. When I explained to them the situation, they were admanent that I wasn't a mechanic and it wasn't their error for the taillight replacement.
    My question to you is this: what is your best guess at what this issue might be?
    Might you have any suggestions on what to say to the dealership for better service or intelligent sounding information to provide them? I feel it is important to learn all I can about my car and how to diagnose the issue.
    Thank you in advance for your help!
    It is my understanding that the motors in the electric window and even moon/sun roof do eventually burn out and need replacement. So, that is an area to start. Otherwise, it might be an electrical issue.
    I had a driver tail light replaced due to a short causing the auto transmission not to shift. Apparently, the tail light switch was a recall from vw jettas 1997-2001.
    I hope this helps.
  • rsenger1rsenger1 Member Posts: 4
    Recently I have encountered a number of annoying problems. For one my doors will lock occasionally on there own. I have removed the batteries from my remote but that didn't solve the problem. When this happens I can not exit the car without setting off the alarm. Anyone have any suggestions.
  • betovenbetoven Member Posts: 3
    Follow up. I had my transsion changed after out of nowhere an internal object ejected-out making a hole in the engine. I was wishing the jerking on my Jetta 2k vr6 would stop but no it didn't.
    So, here i am in the elimination process trying to figure out what the problem is. I am surely not taking it to the same vw dealership after all the money spent and for nothing, so I could really appreciate your imput on this issue to resolve my problem.
    So far these items have been replaced: Coil-Pack, spark plug wires, Mass Flow Air sensor (2 times), Spark Plugs, Oil Filter, Synthetic Oil, Gas Filter, Transmission, Batery, Brake Light switch.
    By the way, the cruise control and the clutch feature(car starts without pushing the clutch in) stopped working after a visit to the dealership. I really hope you could help.
    For anyone with the same jerking problem you might want to hold before changing the parts I changed unless your maintenance tells you so.
    Again, your imput will be SO very much appreciated!
    going the VAGCOM route sounds like a good idea.
    what about a clogged catalytic convertor? would that show up on VAGCOM diagnostics?
    Thanks! Unfortunately I am not able to identify anything "staying on".... and it doesn't do it every time... **sigh**.... am still trying to figure this one out. Any other ideas?
  • mikelsumikelsu Member Posts: 1
    I am the not-so-pleased owner of a 2002 Jetta 1.5. Been a pain, and expesnive since the warranty expired. Had the a sunroof drain problem fixed by getting dealership instructions to trim the rubber hose by the doors with scissors. High tech, eh? Now I have water in my trunk. Is something plugged up that I can readily find and repair?
    The cat has been checked and is clear. I have been informed that maybe it could be the break switch. Has anyone had any experience with this. It appears to be a free part from the dealer and I have told my mech to check it out. Of course I want to get any info from you guys since my experience with mechs and dealers is that they want to charge as much as possible. I dont want them telling me it's not the switch just so they can charge more for an injection pump. :sick:
  • rwatsonrwatson Member Posts: 144
    Please, take the car to Autozone, or Advanced, or wherever and have them test the alternator. That was the culprit for me once. After your car acts up, you jump it and it seems to work for a while. Then it acts up again. Mine did the same with me, and it was the alternator slowly dying. Then one day: :sick: No ammount of jumping would get it going.
    Have fun ;)
  • kingiscmnkingiscmn Member Posts: 1
    I have an 01 TDI with 155,000 miles. Recently the brake lights stopped working and it wouldn't shift into gear. After hearing they had a recall, I called VW here and mine is not in the recall. They told me that the Brake Light Switch was bad. I bought a new one (it is a 4 pole brake light switch) and it doesn't seem to work either. I can bypass the switch and the lights and the shifting into gear works so it doesn't seem to be in the wiring. NOW my glow plug light is flashing...and I still can't get the brake light switch to work...what is going on?
  • 99jet99jet Member Posts: 1
    Hello there ,
    I just bought a 99 Volkswagen Jetta (Wolfsburg edition) , and next hour I bought it my friend rolled down the windows and now it is not rolling up at all , this is the front passenger side. Motor seems to be working but the glass won't roll back up
    can someone reply what would be the problem and if you had already faced this situation , what would be the cost to fix it
    satish
    Search this discussion for "window clips". These clips break.... a common problem with Jettas.
    Did you check that the window lock button is not pushed down?
  • ndodgendodge Member Posts: 1
    I'm hoping someone can help me. I got a 1986 Jetta GL from a friend, and went through the usual repairs after a car sits for a year -- new filters, oil change, some sections of hose, etc. I put it in the shop for a bad wheel bearing and a few other things, and I mentioned the following problem, which the shop said they could do nothing about because it's not consistent.
    When I start the car, it idles fine, and runs fine, until it warms up. Then it has no "get up and go" -- it hesitates.
    It's at another shop right now since it failed inspection for brakes (not emissions). The mechanic had it running for 30 minutes this morning with the heater on, since I had left the windows open and the inside was wet after a rain. He said that when he went back to the car, he could barely get it to move, or restart. (At least he believes that there is a problem!)
    He claims he can't do anything, and that I should scrap the car. I have so much money in it now (and not much left) that I hate to give up without trying everything.
    I really like that car. It's an antique as of June 8th -- any help would be most welcome.
    Thank you,
    Nan
  • doc247doc247 Member Posts: 1
    My wife's 97 Jetta has a strange problem. A couple of weeks ago, the front driver's side window and the rear passenger side window quit going down. Later, they worked just fine. Now, they don't work again. It doesn't matter if you use the console or the door switch for the rear either. The other 2 windows work just fine. I'm thinking wiring issue somewhere....but not sure where. Any ideas!?
  • jlanderjlander Member Posts: 1
    I have a 1998 Jetta that makes a load clunking noise when in reverse and it sometimes jumps out of gear when in reverse. I had the car in the shop for another problem and the mechanic said he thought the noise was from a bearing in the transmission. I have replaced automatic transmissions on older American cards but have no experience with a Volkswagen. Is replacing the transmission something I can do myself? If all that is needed is a bearing can I rebuild the transmission myself ? Also where can I find good information to help me do this work.
  • primecarmiprimecarmi Member Posts: 1
    I have a 2003 jetta that I lost the original key to. I have since brought the car to the dealer and had a new key made. Here is my problem, we have found the original key and lost the second one and the original key will no longer start the car, is there any way to self program the computer or must I take it to the dealership again??
  • chrisnhchrisnh Member Posts: 22
    My daughter's Jetta '96 had several problems right from the 2nd day she had it. I am happy to report that with the help of this forum, we seem to have worked through the issues and in the process found a mechanic that our Jetta (us too) likes. Here is the two year saga and the solutions.
    The first time she plugged her cell phone into Jetta, she blew fuses. She drove it up a 7 mile hill on the way back to College and the engine overheated (no engine fan).
    The "VW" expert who sold us the car, said she should have never plugged in her cell phone without telling him first and we sort of went downhill from there. The Expert had to replace the fan(s) and the big fuse which sits under the clear plastic top. The car never seemed to be quite right.
    We had this stall in wet weather problem (new coil, distributor cap, wires) installed by another Foreign Car expert. Somebody pinched the new #1 sparkplug wire in the process because we could see it sparking when we misted the engine. Many coats of liquid electric tape fixed that.
    We noticed the new fan was not working the next summer and that big flat metal fuse had blown again. We replaced the fuse (AutoZone) with a generic that we sort bent to fit. But the car was drivable. Decided to use the heater to cool the engine because we thought the fan would blow up because of underlining electrical problems with the wiring harness or something. Yep it is not hot around us and usually traffic is not bad.
    Then we had the big oil leak under the car, sometimes. A garage 40 miles away told me it was a bad rear seal. They would have to pull the engine and since the clutch was obviously going, might as well replace that for big money. Had the car taken to a more local mechanic (who is now our guy). Nothing wrong with the clutch and it was not a rear seal. He recommened I degunk the engine and pay attention. Turned out to be a leaking oil sensor. That was easy and cheap fix.
    We had the front end jerk. Probably was ice on the front wheel. But our conviently located American mechanic (oil change, tires etc) noticed the back wheelbearings needed to be replaced. OK, proactive works.
    Then the muffler sort of fell apart. The American mechanic replaced the back half with a cheap replacement. OK, that is one of the reasons we like him. But he doesn't really like foreign cars.
    Once in a while the car would miss and check engine light would come on. The old #1 miss fire (that $35 ODB reader is a great idea) that had all the mechanics stumpted. Then we noticed that the car's gas mileage was getting worse and it did not seem its usual peppy self. I got a call from my daughter on a cold and rainy night that the car had no power. So we decided not to take the car to our American mechanic but to "our guy".
    We ran down this list of problems. Turned out the cat converter had deconstructed (no power), he found generic one and remounted the sensor. He decided one of the grounds looked suspect, so he found a good spot and put in another one. He shared our concern and did some more electrical testing. Once he was happy, then he installed a fan laying around for 5 years that he gave a great deal on.
    Lets see that was 4 months ago and no major problems. We are feeling pretty good about the Jetta at the moment. My daughter thought I should share this with the forum, which really helped me trouble shoot and led me to "our Jetta guy".
  • kristin9kristin9 Member Posts: 1
    I just had my 98 tdi jetta towed in to the shop due to the oil sensor flashing and beeping at me and a tremendous amount of oil leaking. The mechanic told me that the turbo is blown, there is oil in the turbo and that the repair would be around $1600. I am fairly new to the tdi scene so I do not know if there is there an o-ring that could have gone or if there is such thing as a rebuilt turbo to try to reduce my costs. I have a problem trusting mechanics (especially at this price) so does anyone have advice for me?
    kristin9
  • ral2167ral2167 Member Posts: 791
    just called VW service and they say this can't be done...but got differing opinion from jetta owner in another forum...
    just bought new jetta 2.5L.. the doors lock automatically, which is fine, but when i get out of the car and try to open another door, it's locked.... is there anyway that when the car is shut off, all the doors unlock automatically.... as i say, i was told by another owner this was done, but when i just called my dealer service area, the guy said it can;t be done... anyone else have this situation?
    Why can you not push the "unlock all doors" button as you get out? Alternately, just unlock all the doors with the remote.
    Either way, your complaint seems to have several work-arounds that would accomplish the same task that you want to do.
    Check your owners manual. I believe this is covered in there. It gives instructions for those with the computer menu interface. As I said eleswhere, our VE doesn't have the computer interface, but dealer made the change. I am also assuming that this feature did not change...ours is a 2005.5, I assume you have a 2006.
    I can give you two dealers for you or your dealership to contact, if they continue to not be able to figure this out. The one we bought the car from (Zimbrick VW in Middleton, WI) told us at the time of delivery that the locks could be set up this way.
    The dealership that actually made the change for us is Ernie Von Schledorn VW in Menomonee Falls, WI.
  • lilafaerielilafaerie Member Posts: 4
    I need help with my Jetta. It's a 1994 VW Jetta III, 2.0 ltr, 4 cyldinder, manual and recently it's been stalling on me. It seems to be a problem that I've had with the car for quite a while. It started with the car hiccuping a bit when accelerating between gears - I'd give it gas and it would hesitate before the car responded. It's since gotten worse. The MIL light started coming on when the car would do this and it became increasingly more difficult to balance the clutch and gas and has even stalled out on me.
    I took it to a mechanic, someone that I've trusted and that has saved me money in the past, but they took a look at it and put it through the computer and told me that it was the 4th cylinder mis-firing and that it would require me to get a tune up (something that the previous owners had NEVER done). So they replaced the wires, plugs and cap (or something). I got the car back and it ran fine for a day and then it started acting up AGAIN and worse. It seemed to be worse in traffic, when the car was hot and idling. I took it back to the mechanic and they told me that they could not reproduce the issue, so I took it back. A few days later the car got really bad. On the way home from work it would constantly stall. The RPMs would drop and the car would stall at every single light.
    I took it to another mechanic that I also know and he cleaned out the manifold and then was going to return it to me, however on his way back to me the car started acting up on him and he realized that there was a much larger problem. He then suggested that it was the throttle sensor which he was 99% sure that it would need to be replaced. So $170 for a sensor later and the car is STILL acting up.
    I don't know what to do from here. Does anybody know what this could be? From reading this forum it seems like it would be the wires - maybe they're not on tight? Any feedback is greatly appreciated!
    -Erin
  • cosmocosmo Member Posts: 203
    Based on the age of your Jetta, the symptoms you've described, and the fact that the previous owner had never tuned it, I would check to see if the catalytic converter might be clogged.
  • teoincateoinca Member Posts: 1
    I bought a Jetta GLI, very nice car I got it with Nav System and Package #2 with Sirius. The only "big" problem is the sales person was not knowledgeable enough. They sold me the iPod Connector without letting me know that if I get the iPod installed then either my Satellite Radio or my Six CD changer would not work.
    Also the MP3 capability is gone if you get Nav System. However the salesperson told me that it was possible to use MP3 that was BS. So beware of those problems.
    I am still doing some research to find out if there is any iPod connector that I could use my CD changer, or Satellite radio. If someone knows anything please let me know.
    Other than that I love the car. I highly recommend the 2.0 turbo engine it works very nice. You can race with any sports car.
    How about not being able to lock your car for months and then the alarm decides to go off? This happened tonight. The key has not been able to the door lock, which I thought was the SOP to reset the alarm. Now what?
    I don't think it is your remote. Sympathies. Anybody got ideas.
    Think I am going to have to pull the door apart because I don't think I can pull the car's brains out. This could get ugly, I don't want to pay the big bucks for a new lock but....
    Phil,
    Wonder if I am translating your post correctly (over a year old). If I carefully pull the door apart to get to the door handle, I could discover a broken link which prevents the key from turning?
    My current problem is the alarm have decided to go off and there is no way to reset it and start the car (that I know about). Chris
  • jdb47jdb47 Member Posts: 4
    '00 Jetta driverside daytime/regular light goes out, but both brights work perfectly...I know this is an easy one, but I'm still clueless...is it the same bulb for dim/brights and just a fuse issue, or are there two separate bulbs and I just need to replace the one? Thanks for the help.
    Ah, it is a good idea to be able to turn the key in the old Jetta. If the alarm ever goes off, say a loose battery terminal or something, how to you disarm it? We could get into the honking car which was located 10 miles from home. Here is a brief step by step, allow an hour, should take 15 minutes.
    Have your radio safe codes handy. Carefully disconnect the battery. Open the driver's door (or passanger's). Roll up the window. Put the key in the lock. On the post side of the door are some star (hex) headed screws. Undo the one that is on the same line as the door handle (top one). Push the part of the door handle that has the lock towards the front of the car, about an inch. Then pivot that end out.
    The tricky part is that there is a verticle metal door release that is still attached to the lock. If your key works, you can turn it in the lock and it will free the release. But with a frozen lock, I had to do some gentle stuff. On one of my doors it slipped out and I removed the handle/lock.
    There is sort of a flat piece of metal with a spring around it that sticks out from opposite of where the key goes in. That piece of metal fits into a slot which you can see inside the door.
    The slot is what your key turns. Connect the battery, now turn the screwdriver just like it was a key to disarm the car. I believe the door handle has to be in the car for the car to start. I did not worry about messing with the door release, I carefully reinstalled the handle and drove the car home.
    Then I pulled the handle again. I used a degreaser and some light oil, outside and inside the lock. With the key in the lock, carefully used some pliers on a bit of the lock cylindar I could see opposite from where the key sticks in, to assist the key in turning. I got lucky on both door handles after giving each 5 minutes of attention. I can lock and unlock both doors.
    I don't think anything was broken, just rusted, gunked or yucked up after 11 years of road sand and salt.
    If the key will not turn, getting the door release back into the right position in the lock/door handle is difficult (second door was a lot more difficult and that is when I discovered the pliers helped). TIP: Now that I know what is going on, I might have been able to slip a screwdriver in the slot without taking the handle out of the car. Got to be careful of the window, which will be sliding up and down as the car unarms itself.
    I am a happy person. Didn't spend a dime. Didn't have to remove the internal door panel. Didn't lose any of the springs on the door handle. I could have done it at 10 PM but glad I went back and became the hero in daylight.
  • minny2minny2 Member Posts: 1
    for past two months car has failed to start at times, after waiting 5 min or less it starts. last week car stalled at light, failed to start- was towed in and when mechanic looked at it it started again. We have a new battery and the car turns over, no other lights on. Help- the mechanic can't get it to duplicate my problem and I'm very frustrated. Although I love to drive the car (1.8 turbo-2000) it has been a money pit from the start.
