Volkswagen Jetta Maintenance and Repair
1108109111113114131
    bpeeblesbpeebles Member Posts: 4,085
    I have never heard of a clutch without a throwout bearing. What would take the load when the clutch is disenguaged?
    This is a great time to remind everyone that one should NEVER sit still with the clutch pedal pushed.... you are ASKING for premature throwout bearing failure. (Only push clutch pedal to shift gears!)
    Also, clutches that wear out have been mis-used. I have traveled over 200K miles without any clutch wearout. (Clutch lasts useful life of vehicle.)
    SECRET: Do not touch throttle pedal until clutch is fully enguaged! It is possible, I tought my daughter this trick and she can now drive a standard smoother than many automatic xmissions.
    jeffyscottjeffyscott Member Posts: 3,855
    I don't even know what a throwout bearing is, but I never drove the ways you suggest, nor did my kids or wife. We never had a clutch problem during the entire life of any of our manual trans vehicles (ranged from 110,000 miles to 150,000 miles).
    600kgolfgt600kgolfgt Member Posts: 690
    Assuming you have the 4-cylinder 2.0 liter Jetta with the 020 5-speed transmission, the release bearing is located at the aft-end of the transmission. Remove the green cover at the end of the transmission and you will see the release bearing. This is the type of job that can be performed without removing the transmission....
    I have a 1997 Jetta as well... :shades:
    eggenseggens Member Posts: 2
    Thanks, 600kgolfgt. I was able to locate and replace the throwout bearing while I had the transmission out. I'm putting it back together and am a little panicked about something. I noticed that the clutch cable was way too easy to put back onto the lever. I seem to have almost no resistance; the pedal goes almost all the way to the floor before there is any back pressure. I know that the clutch is "self-adjusting", so I'm hoping this is normal and the transmission needs to be spinning to adjust (I haven't fired it up yet). But, I'm hesitant to button everything back up until I know I'm okay.
    Anyone have any insight?
    apparently there is a procedure for compressing the clutch cable? Have you done this?
    If so:
    1. Make sure clutch cable adjustment mechanism is compressed.
    2. Coat clutch cable suspension point at the clutch pedal with grease.
    Clutch Cable
    3. Press the clutch cable through the bulkhead and suspend in front recess of the clutch pedal while making sure that the load plate is installed on the clutch cable
    4. Route the clutch cable and end piece through the bracket on the transmission and through the release shaft lever while taking care not to damage the plastic sleeve on the clutch cable.
    Clutch Cable
    5. Hook attachment parts onto release shaft lever
    6. Suspend the clutch cable in wire holder.
    7. Install the over-center spring. See: Clutch Pedal Assembly
    8. Depress the clutch cable several times.
    9. Check the operation of the adjustment mechanism.
    Or if all else fails, do what I did - replace the self-adjusting cable with a manual-adjusting cable. What you lose in self-adjusting capability, you gain in one less additional mechanism that can potentially break (I prefer the direct approach to clutch actuation)...:)
    maylmayl Member Posts: 1
    Hi, this happened to me and I found the fuse was blown, check your fuses. Apparently this happens a lot on our cars because the dome light shorts out the fuse. I disconnected my dome light and it didn't happen again. Good luck.
    01vr6_fun01vr6_fun Member Posts: 1
    Hi, I'm new to this forum, but I spent about 3 hrs. reading old posts and like what I've seen, thus decided to post few questions of my own. Any tips much appreciated.
    1. i'm driving a 01 Jetta VR6, and I get about 19-21mpg driving 90% highway, avg speed 80mph. I'm not complaining, but like anybody else, wouldn't it be nice to get 30mpg? :D One thing I've noticed is that I get about 24-26mpg when the weather is warmer over 70 F (I live in MN, by the way we expect snow this weekend). Any clues why the change in mpg with the weather, should I change anything to get better mpg?
    2. I do a lot of the maintenance myself, recently changed plugs/wires (from the dealer $, after reading too many reviews I decided to stay with stock); but use fram for filters (oil&air). for oil I use Mobil 1 synthetic 5-30 winter & 10-30 summer. Are those bad, is there a better brand that people use? :confuse:
    Just want to hear some opinions. :shades:
    autowork7456autowork7456 Member Posts: 15
    Ok we are ready to purchase the VagCom but how do you know which one to buy? Thanks!
    For home use (single license), there is only really one choice. You purchase the cable (interface) that will plug into your Laptop computer to your car.
    If you are still confused, there are several helpful webpages to visit on the ross-tech website that can help guide you. Their What to buy webpage is very helpful.
    Also, you can just send an eMail to them. They have always been responsive to my inqueries.
    I assume that you know that anyone can just download the software as often as you wish. (I visit the VagCom site several times a year and download the most recent version.)
    Thanks, we appreciate all your help.
    grayson1grayson1 Member Posts: 5
    My Thanks to everyone who responded to my post a few months ago about my neighbor who insisted that my cat was peeing on her tires and causing her Jetta wagon to smell like cat urine.
    The information you all provided helped me document that a mechanical inspection was needed. When she refused to do it, she also had to abandon her legal threats. I never spoke to her again (although she confronted me in the parking lot whenever she could).
    Apparently, she had other issues that caused her to have to move away - far away.
    Thank you so much. I was really stressed out from her legal threats and I couldn't have survived it without you all!
    tds654tds654 Member Posts: 2
    My wife has a 2000 Jetta VR6. She is only getting about 20 mpg. Is this normal for the V6??? Is there anything I could /should do to improve it?
    TS
    Revised EPA rating is 17/24 for automatic and 17/26 for manual, so 20 is certainly within the range of "normal".
    http://www.fueleconomy.gov/
    jcuevajcueva Member Posts: 1
    Hi all:
    When I accelerate my Jetta at low gears, acceleration is very jerky like the car only feels me pushing the pedal intermittently. It does this all the time now, and twice, while driving, it drops into "limp-mode", and I have no acceleration whatsoever. If the car is turned off and restarted, the car goes back to jerky. The EPC light and the spinning tire come on when it goes to limp mode. The jerky acceleration can be felt mostly in 1st to 3rd gears, it is harder to feel in higher gears. Does anyone know what may be happening?
    I appreciate the info,
    jp
    revmarketrevmarket Member Posts: 48
    Have the ignition coil checked,
    An ignition coil that is arcing will sometimes cause transmission like troubles without it actually being the transmission.
    Do not waste your money on an after-market coil. Spend the extra to buy an OEM from VW. Mostly the after-market one will not stand up to the extreme specs of VW engineering.
    allwedrivrvwsallwedrivrvws Member Posts: 1
    I bought my first Jetta when it was 7yrs old, did a few change overs like the Corrado owner above. (Or, I should say my bf did). Corrado G60 downpipe, new springs/sport suspension for a great firm ride and of course, the lower profile rims and tyres and I have to say for a black car and my first standard - never had any problems with the paint or even the clutch. The clutch was only changed once, when it needed it. And I had 11" Wilwood brakes on the wheels so they didn't even need to be changed during the 7yrs either. (And I'm not the easiest girl on a car, that's for sure). I take care of them for sure but, I will push them to their limits and do know more than most females, unfortunately. (Osmosis, I think)? His hobby sort of became part of our life. It takes us all over for his photo shoots and for TV spots to watch the cars he's built race all over as well.
    And for my first Jetta and having owned it for 7yrs and then selling it easily for $5 less than what we bought it for, I have absolutely no complaints. That, and the fact that I'm onto my second black Jetta and haven't had anything wrong with this one either - just bought a GLS that's fully loaded and is having an engine swap soon.
    First Jetta made it from Vancouver, BC down to Seaside Oregon on one full tank of gas so for fuel mileage, definitely beat out any other car I've had or he's had. Can't beat 600kms on one tank of highway driving. And my newer one (which is a '95 still goes about 570kms before you push it too far. I've never gone until the car has died). It's a 2.0ltr right now and I can say that with only a different exhaust system on it (all stainless steel from front to back) I can still beat a brand new automatic Camry off the line. And the pick up in fourth is far superior to most cars I get to try out.
    I know that Corrados looked great in their time and it was one of VW's sporty cars but, anyone that does play around with this line of cars or knows these cars really well and is going to give you the best output for your buck, will never recommend a VR6. VR6's were replaced with the 1.8Turbo because the VR6's were too finicky and were crapping out too soon. They overheat and die out too soon. Even with modifications, they are quickly going the way of the G60-which was a horrible engine. Overheat and die really quick. (That's why you won't see those in any of VW's cars anymore.
    1.8T is the way to go if you want more power and easily modified by chipping them. VW's are going more to the Audi side of the family so we're now reaping the benefits of the more expensive end of the family for the lower end prices. Another reason why VW doesn't want you to call the VW's A4's - too much like the Audi's. So they've reverted back to the original way of determining the years - MarkIV, MarkV, etc.
    As for your last comment about the Jetta being grossly under tired and having too much bodyroll, what do you think you're paying for when you buy an Audi? Look at the specs between the two and you'll be surprised - just like what I was saying...other than the same rims and lower profile tires - the chassis are becoming very similar these days. Have you not noticed the similarities yet? Befriend someone at VW or an aftermarket shop and they'll show you. You're going off the premise of, "it's gotta be better because it costs more."
    Check out the high end Jetta and then the Audi...the specs aren't that much different. (Sorry for the disillusion). ;)
    gmangman Member Posts: 5
    Any 2006 Jetta owners out there that have received a letter about participating in a testing program? The letter is from Automotive Testing & Development Services (ATDS) and it seems a little weird. It appears that the study is sponsored by Hyundai. They want to borrow my Jetta for 3 days. In return they will give me a midsize car with a full tank of gas. After 3 days, my Jetta will be returned with a full tank of gas. ATDS will pay me 200$ for this two weeks after the test. The car has to be dropped off and picked up at the Hyundia Tech Center near Ann Arbor Michigan.
    Is this a scam or a legit test study? Anybody have experience with this kind of study?
    turtlejettaturtlejetta Member Posts: 1
    Okay so i just bought a 2003 Jetta 1.8T about 4 months ago and itz running very weird..The car has a huge loss of power a 1989 Corolla can beat me no joke...bad pick up bad power..it doesn't feel like 180HP...instead feels like 50HP...i got a check engine light for a cam sensor circuit malfunction and i was wondering if anyone would know if that could b a reason for the huge power loss..Thanks i appreciate it
    A CEL may force the engine into "limp mode" and disable the turbocharger.
    gatorlane77gatorlane77 Member Posts: 6
    2003 Jetta GLX
    Every other time I stop at a stop light, my engine will start to hum with a deep loud sound. I can feel the vibration too as if it were a belt vibrating heavily. Also, when this happens, my A/C loses its coolness and if I either let off of my brake and start to accelerate or turn off my A/C the humming will go away.
    Is anyone familiar with this? Do I need to tighten the belt somehow? I opened the hood and looked, but did not see any belts that go to the compressor. I couldn't even see the compressor. This is my first European car and I'm used to American cars where I open the hood and see a serpentine belt and can tighten it right up.
    Thanks for your help.
    Modern vehicles have a serpentine belt that has its tightness maintained by a spring-loaded "tensionor". There is no human-adjustable components on the serpentine-belt system.
    VWs do not use a "clutch" on the AC compressor like some other vehicles. That is why you do not feel the AC compressor kicking in and out. Instead, the AC compressor is "variable" and changes the amount of freon it pushes based on cooling demand and engine speed.
    Perhaps you would want to check that the AC system is properly charged with freon (or whatever it is charged with).
    Thanks for the reply. When I'm moving (and sitting still to some degree) the air is ice cold. The only time I notice it blowing warm is when the loud vibration/humming occurs. Do you have any idea why that would be occuring? Thanks.
    kap216kap216 Member Posts: 1
    So first my speedometer would go all wacky once in awhile, go up to a 160 mph for instance when i was driving about 80. Now the speedometer sticks at zero and my rpm sticks at zero. Using the other displays in the car, i know that my mileage is not suffering ( I still get around 26 mpg on freeway). What are possible causes? Should I take it to the mechanic?
    Suspect the wiring to the console. Most likely a ground connection.
    jettagyalgojettagyalgo Member Posts: 11
    Hello, I have a 2003 Jetta GLS.
    Today my Malfunction Indicator Lamp came on.
    My car is due for an oil change either before Feb. 2008 or before I hit 33967 miles.
    Currently I have only 333391
    As I was going to take my car in this weekend anyway..does anyone have any idea what may be going on here? The booklet says the emissions and don't drive fast or any steep hills, but I really as you can see don't drive it as much. When I got the car in 2006 it had 22000 miles approx.
    Any insight would be helpful. especially on the how much this would cost approx. I need my car!!
    Thank you! :cry:
    jodar96jodar96 Member Posts: 400
    Last year I passed on buying a 2000 Jetta. This year, I am back trying to buy a 2001 Jetta for my son.
    It has 85K miles, manual, with 2.0L engine. The guy says it uses a quart of oil every 1500 miles. The VW dealer says a quart of oil every 1000 miles is normal. It may be normal for a bad design, but it is certainly not normal for a decent engine. My 2001 Mercedes E430 with 93K miles that holds 8.5 quarts does not use ANY oil between its 10K oil change interval, nor does my 93 Ford Ranger with 153K miles.
    My question is this...will this oil consumption get worse with time? or it will remain the same?
    Also I thought the timing belt/water pump replacement is due at 100K. My local VW dealer says pre 2002 it was at 80K. Is he trying to sell me the $700 service or is it truely needed at 80K? I know the timing belt failure is a distaster on VW/Audi engines and I will never take a chance on that.
    Has anybody had timing belt failure before 100K miles?
    One last question.. can I request water pump with metal propeller instead of one with original plastic one? I know there were some water pump failure where the plastic propeller broke in pieces and they ended up in the engine and the radiator.
    Joe
    ruking1ruking1 Member Posts: 19,826
    If it were me, I'd pass,.I also understand 1000 to 1,500 miles per qt is considered "normal". Basically in a 10,000 mile OCI, 1000 to 1500 miles per qt (add 7-10 qts MINIMUM ! ) means you;ll "change oil" over 2 to 3 times!!! My swag is the oil consumption will probably increase.
    I say this as a 03 VW Jetta TDI owner with 107,000 miles looking to go a min of 500,000 miles. Current oil consumption is 1/8 to 1/3 qt (4 oz to 11 oz) in the course of a 25,000 mile OCI. (yes I know the oem recommendation is 10,000 miles)
    03 TDI timing belt changes are at 100k. However this presupposes the bigger bearings and improved belt. So IF the smaller bearings and (non) improved belt is/are used, then yes the lower mileage interval is prudent. This needs to be verified to say one way or the other. No, I have not had T/B failure. I have personally seen 15 or more old belts ( TB/WP jobs). While visual inspection can be deceiving, my own belt changed at 100k looked good to go for another 20,000 miles as a minimum. Also the oem water pump plastic impellor showed signs of coolant seepage. As you mentioned it is way foolish to chance this. Of the belts I have personally seen, there indeed were a few where you " knock on wood" they even made it before the change.
    Yes you can request/get the W/P with metal (brass is best) rather than the "plastic". Laso makes the brass impeller one. Lastest research indicates the Laso, brass impellor is the best. The complication is the water pump is made by a few vendors, Bosch, Graf, Hepu, Laso comes to mind.
    Not to add any more complication, but Laso also makes a "composite" (aka RESIN) impeller (so does Graf. :sick: ). To LQQK at the "composite" aka resin, one side by side with another make's (Bosch makes oem) "plastic" ones does not help much as both LQQK PLASTIC. Please also be aware (sans Bosch "plastic" ones) that a TDI guru that I respect makes an argument that "resin" ones such as Laso, Graf, actually flows coolant better.
    dfdaviddfdavid Member Posts: 2
    Late model 1999 Jetta 2L
    Check engine light appeared so I used code reader u380 and found problem with misfire in #4 cylinder. Changed spark plugs and then tried to start engine . no response except when key is turned on, clicks are heard and flashings on control panel are seen. nothing electrical works ie. windows radio Code reader now shows "link error" when used. What could it be ?
    new model 1999 Jetta 2L
    lentelocolenteloco Member Posts: 5
    what type of freon does a 97 jetta gls use, R-12 or 134A?
    I'm pretty sure that by 1997 no one was putting R12 in new cars.
    http://www.motortrend.com/features/car_care/112_9510_new_car_care_products/index- .html
    Most '94 and virtually all '95 models use CFC-free R-134a.
    Starting in 1994 all manufacturers were required to start using R134A. Your Jetta uses R134A.
    Thanks for your comments. I said water pump's " proppler" knowing it is a Impeller. I wonder if there is anything can be added to engine oil to slow down the consumption. or one oil brand or slight viscosity variation will slow down the oil useage.
    Are you saying you go 25K miles between the oil changes? Unless you are doing 100% highway driving in 70-90F ambient temp, I am not sure I want that oil hang around in the engine that long.
    If I end up buying this Jetta, I will look for W/P with brass impeller.
    Joe
    tony2000tony2000 Member Posts: 1
    Help! my son has a 2000 Jetta non turbo, starts and runs fine up untill it reaches temp then the check engine light comes on and it shuts the engine down. Have tried to have codes read and it keeps coming up (unable to read) have tried 4 different code readers. Thanks for any advice.
    No to both questions to make a long story short. That is one major reason why I would pass on the gasser VW engines.
    Yes I am am saying 25k miles OCI's :shades: Again to make a long story short, a good reason why I got lucky on the 03 TDI. :shades:
    brooklyntechbrooklyntech Member Posts: 6
    I will be gone for 4 weeks, Is it OK to leave car in June, outside without starting it?
    If it were me, I would not worry about it. I once read a recomendation that if you are not going to use your car for an extended period of time, you should start it and warm it up about once every two weeks. So I would guess going twice that interval just one time would be unlikely to create any problems, especially with it being summer.
    I am buying that 2001 Jetta with 85K miles that uses a quart of oil every 1500 miles. I need to know if any of you out there that have this issue, knows of any oil brand/special weight that slows down this oil consumption beside parking the car in the garage and not driving it.
    It is amazing how VW calls this defect "Normal". I had an 85 Jetta, bought it new, put 180K miles on it. That Jetta never had the oil consumption problem. I wonder what went wrong some 16 years later..
    Joe
    woody54woody54 Member Posts: 1
    My 1997 Jetta Gl code 1582 keeps comming up. Sometimes 422 will come up after I drive it for about 50 miles. Cleaned the tb and mass air flow. 1582 still comes up but the light isn't on. What else can be done to get the code out, and pass emission test.
    Woody54
    paulanthonydfwpaulanthonydfw Member Posts: 6
    Hello VW people. I just purchased a 2003 Jetta GL with the 2.0 engine. I have never owned a VW before. It has a little higher mileage at 80,000, but has a clean car fax and looks and drives great. Can anyone suggest some maintenance that I might need to get done other than an oil change. Thanks, Paul in Dallas.
    My 2003 TDI has nearly 100,000 miles... and I fully expect another couple 100,000 out of it.
    *)Clean the "snowScreen" (there is an online movie showing how to do this)
    *)Make certain the foam pads which cause rust have been addressed. (There is a TSB about this)
    ENJOY YOUR NEW CAR!!.
    smkladakissmkladakis Member Posts: 1
    I have the same problem with my 2000 Jetta. Were you able to figure it out?
    p100p100 Member Posts: 1,116
    What went wrong? Quality went down the toilet after they started making Jettas in Mexico and started using globally manufactured parts..
    The reasons for the "oil consumption" issues are complex and described in detail elsewhere. Usually due to poor/improper engine break-in when new.
    In any case, oil-consumption by itself is NOT a problem. Just keep oil in the engine and it will last a long long time. In fact, it can be argued that the oil "changes itself" as you drive.
    Also, there are some things you could do to minimize the consumption.... but keeping a case of oil in the trunk is the cheepest.
    Please keep in mind that VWs have been ASSEMBLED in Mexico since the original beetle.
    HOWEVER: The sources for the components are many. Xmissions come from one country, engines from another. The Mexicans just bolt the components together. You really cannot blame the Mexicans if an engine built in Brazil consumes oil.
    freetiger777freetiger777 Member Posts: 1
    Hi there!
    I was wondering if anyone got back to you regarding this question... my MIL came on last night as well, and I have no idea why?!?!?!... I have a 2003 Jetta and it has 33000 miles. There's never been anything wrong with it except for an electrical problem that was solved under warranty... but I don't know how much I"ll have to spend if I take it to the dealership ... I check the booklet and it's exactly what you say. Don't drive fast, no Steep Hills, etc.. ugh.. ...any insight?
    Thanks so much for any help! :confuse:
    If it is just "ON" you are safe to drive your car while you decide the best course of action is.
    If it is "BLINKING" - DO NOT DRIVE because there is immenent danger of bad things happening. (catalitic converter overheating...etc)
    If I were you, I would take car to autoparts store who often can "pull the codes" from the onboard computer for you. (and reset the MIL at the same time)
    This will NOT fix the problem.. .but knowing what code is causing the MIL will go a long way twards figuring out the next step to take.
    younggotti167younggotti167 Member Posts: 2
    ok i've had this problem for a couple of weeks now, but i dont know what the problem is! After doing a great deal of driving, whenever I have the car at a stop or on idle, there is like a ticking sound coming from the right side. Only thing is, i can only hear it whenever im sitting inside the car, and cant when i have the hood popped. Anyone have a clue? I bought the car at a Dodge dealership and they dont have a clue, Im planning on taking it to a VW dealership to have it checked out. It only has 38,000 miles so i cant see what the problem could be.
    Also, my steering wheel shakes whenever i drive around 80 mph on the highway. Is that normal?
    Nothing jumps out at me in your first paragraph. It however can be a number of things.
    Your steering wheel shake is probably a tire or two that is out of balance.
    kenadelekenadele Member Posts: 3
    2001 Jetta 1.8L. Trying to replace the fuel filter, but I can not remove the clips on each end of the fuel line. Is there a trick or one of those "special tools" needed?
