2010 and 2011 Ford Escape RV towing problem with transmission problem.
I have towed my 2010 and 2011 Escape AWD behind my motorhome. Both transmission failed while being towed. I lemon lawed the 2010 and won then moved to the 2011 as I was told the transmission had been successfully modified. My 2011 transmission failed in July 2016 and I've filed a complaint with the Michigan Better Business Bureau against Ford Motor Co. I have seen other blogs about the same problem I have and want to connect with other RV owners who tow an Escape AWD. Is this possible here?
Answers
