Any idea what this small radiator is, so I can have it replaced?">
We're sorry to hear that you're having difficulty with your Suburban. What are your plans for getting this looked into? If you would like for us to check into any existing warranties or recall information, please email the last 8 digits of your VIN to [email protected]
Sarah, GM Customer Service
2001 suburban 1500 about 145k miles.
In gears 1 and 2 I have no problems whatsoever. But in 3 and D, the car randomly shudders, and stalls. This is much worse when the car is loaded up and going up hills. Took it to AAMCO suspecting transmission problems but they say that the transmission is perfectly fine. They have been looking at it for two months!! Replaced crank position sensor, neutral position switch and even the ECM! But nothing is fixing it.
I need help!!
Side note: This only happens on slow accelerations, if you step on it from the gate it would take right off. Also though the bogging down would happen every time, it would not flash traction control on the dash every time. It took me at least 15 times in a row before I got the traction control message.
Hope this helps someone.
when i put it in gear it goes 100ft or so disegages then i have to shut it off and wait 5min it will go back in gear and do the same thing over again i changed the trans oil and filter it still does the same
John
2001 Suburban LT 1500 AWD LSD 5.3L
