Is there really a difference in brands of gas?
graphicguy
Member Posts: 14,242
in General
We've all noticed that there is a substantial
difference in the price of "name brand" gas and the
gas you can buy at your local "el-cheapo"
place...sometimes as much as 30%.
I have heard that all gas must meet federal
requierments and that all gas is bought from the
same refineries, regardless of brand, and just
trucked to different branded stations.
Some stations use methanol in their gas. It's
been around awhile and seems to be accepted by all
the major car manufacturers. It is cheaper. Some
advertise their gas in "pure".
My question...is there really a difference? Do
they all have to have the same additives to meet
local and federal/ local requirements for cleaner
air? Are we just paying higher prices at places
like Shell, BP, Amoco, Sunoco, etc. just to pay for
their advertising?
An anyone shed some light on this or tell of their
experiences?
their advertising?
experiences?
My mom's old caravan won't run on the cheapest 87 octane (pinged horridly and no proformance), but was fine on anything else.
My 88 S10 hates the premimun gas of the local cheep station (station only sells 90 octane, for less then anyone else sells 87) but runs fine on most others. (there is only other station)
If I get bad tank of gas, a tank of Amico Silver will restore proformance faster then anyone else's. But after half a tank of good gas I'm fine (octane doesn't matter) so I rarely pay extra. Amico is generally more expensive, and while I belive it is better, it isn't enough better that it is worth the cost.
There are some areas around where I live where all the gas is cheap but good quality I go their if I can make it on my way. (10 cents a gallon isn't really worth 30 minutes extra but is worth 5)
I have never experienced differences in brands. I've just filled up at any station that was convenient or cheaper. I know that there are definite differences in octane ratings and always use whatever octane rating the owners manual calls for.
Hasve these federal requirements made "brands" of gas the same since they all have to meet them? I don't know when these requirements went into effect, so maybe the research that was done a few years ago, wouldn't neccessarily be valid today.
Any "bad" long term effects possible from using the cheap stuff as compared to the "branded" gas?
I believe that name brand fuel contains less "impurities", such as dirt, residue, and contaminants that should be removed during the refining process. The dealer also has a lot to do with the quality of fuel, depending on how well the ground tanks and fuel pumps are maintained. Fuel pumps at service stations ("service" stations, now there's a name that's becoming archaic!) have a filter much like an automotive oil filter. When it becomes clogged with contaminants, the fuel delivery from that pump will be slow. Avoid those pumps if you can-you don't know how much contamination is bypassing the filter and ending up in your tank.
I stay with the major brands in So. Cal., Shell, Union, Mobil, Texaco, Chevron, etc. I haven't had any problems. Recently, I had to replace the original fuel pump on my Taurus which means completely draining and lowering the fuel tank since the pump is inside the tank. The tank was clean inside. I didn't find any dirt or debris inside at all, and that's after 145K miles.
Gasoline from the refineries has to meet certain federal standards, yes. Like the motor octane number (MON) must be 88 or above. The refinery octane number (RON) can be any value. The resulting average (R+M)/2 is what determines the octane of the fuel. There are a variety of products that come out of the refinery-- high sulfur, low sulfur, ethanol or methanol blends, detergents and so on. Once it leaves the refinery a distributor may add their own oxygenates and detergents and then it is sold to a retailer. Generally speaking the retailer does nothing but sell it at the pump.
The best performance will be had with no ethanol or methanol additives and low sulfur content. Shop around, but the EPA determines what type of gas you get in your area. If you're in a high-smog part of the country, you probably have crappy gasoline. Of course, this crappy gasoline reduces emissions.
-Colin
(IT professional for one of the big oil tycoons rea98d mentioned)
Using Raceway premium my car gets 28mpg.
This is the same driving habits and same roads being used. Mostly city driving.
Nobody adds ethanol to save money-this stuff is more expensive than crude based gasoline and it is only in there because a bunch of politicians determined it would help the environment and make the farm lobby happy. Now there is evidence to suggest ethanol actually increases pollution-it will dissolve any rubber o-rings in your fuel system and kills older style fuel pumps. I have replaced a couple of pumps and o-rings.
Was riding with a friend in the country-he was a little low on gas and decided to fill up at a really sleazy looking station. Bad bad mistake. The fuel was loaded with very fine black debris-clogged the fuel filter, ruined the injectors and had to remove the tank to clean it out. Somebody told me that some stations buy crap like this when going out of business.
Can you get water out of a gas pump-yes. It is more likely to happen with a low volume station but I got water from a big high volume station and what a pain.
Buying gas from places like Shell, Amoco, Sunoco, Exxon, Texaco, etc. will cost more, but you do get a benefit. I figure that buying better gas costs me about an extra $60 per year. If it keeps my engine running well and keeps me out of the shop, it's well worth it. I don't know this for sure, but it may even be preserving my gas mileage, which is saving me money too.
As for octane. It is fine to burn a higher octane gas than you need, but you would just be wasting your money. Use what your owner's manual recommends unless you have a pinging problem.
this RED CONTAINER additive that is supposed to remove water and clean out fuel injectors.
BIG MISTAKE. My car seems to hesitate as you take off. Have filled the tank 4 times with premium
grade fuel from almost empty and still a problem.
Any thing else I can do?
years ago I stop by a Hess station and filled my olds with it, I havn't been back since, funny noise all over the engine after it was filled up,
and it's the right kind of gas, now 2 and half
cars and 10 years later, I always use the wrong gas, (87 for 89 and 91 ,93 octane cars), and it
always runs fine, I rather buy gas from some independent gas stations rather than stop by any
Hess station, don't try to convert me.
Today, I'm sure there a some differences although probably not much and maybe not any between some brands.
One I do know is different is 'Sheetz' gas. Where most gasoline is a light golden in color, Sheetz' is lime green.
My car is a '99 civic dx 5spd.
Will not mention any brand names, but from my experience its usually not bad gas, but a mech. problem. Buy from the same station and the refinery should back up their product and if you do have a problem they should take care of it. Oh, I buy at the same station and know people who insist that there is water in the station tanks and will not buy there. Point is that I have not had a problem with gas at this station in all the years of buying there, yet others do (Think its their cars problem, not the gas)
Pat
You have to ask the station about their brand additives, but I don't think the gas jockeys can tell you much as they just pump or run cash register.
Regarding octane. A high octane gas is NOT better than a low octane gas. Octane's sole purpose is to prevent premature ignition in the combustion chamber of the car. Why is this useful? Well, some cars run at relatively high combustion pressures (e.g., small engines, sports cars, turbocharged engines, etc). In such a case, the octane prevents the gasoline mixture from igniting in the engine before it should. Premature ignition is what causes the "pinging" or "engine knock" that everyone knows about.
Therefore, look at your owner's manual. If it says you need premium, use it. If your manual says you only need 87 octane, use it. The level of octane in gasoline has absolutely no bearing on "quality." Remember this next time you see a commercial that claims their best gas is their "premium", high octane gas. Higher octane gas doesn't even cost hardly any more to produce. The oil companies just advertise like this and sell it at higher prices to give the impression that it IS better.
