Electrical prblems 2005 Chrysler town and country
I first noticed my headlights and instrument panel lights flickered over bumps. then the instrument light panel lights went out. then the blinkers stopped working. I replace the fuse and got the blinkers back but not the instrument cluster lights . recently the power door lock stopped working and the windshield washer stopped working I disconnected the battery and reconnected it and got the door locks back but the windshield washer still doesn't work . I've seen a lot of discussion about replacing the ECM and BCM how can I test to find out what the problem is?
Then I would check your fusible links, coming off the + post of the battery.
Then I would do a "jiggle test" under the dash to see if by moving a harness or connector, the problem can be duplicated. That would give you at least a hint of what circuit or area might be causing the problem.
Beyond that, there's not much you can do unless you have the electronics diagnostic skills, the instruments and a wiring diagram to isolate each of those circuits and find the source of interruption.
