Wheels
So I had just changed the wheel hub, new rotors and pads on 2006 Town and Country. When I turn even just sitting still turning steering wheel, it has this feeling of rough and shaking. Tire pressure is fine, everything torqued correct, and everything done right. The gas pedal feels a little more still now thinking thats because of the new bearing hub. The rough turning has happened before but I greased everything and was fine. I greased again and it went away. But drove it around for a bit and the problem is back. Runs great just when I turn the steering wheel. Moving or sitting still. Its not like a insane amount but enough to make me wonder what is going on. All seals and boots are sealed and closed so no greases is leaking out. Last year already changed the struts and also the sway bar. It just dont make sense. Unless I was supposed to lube the inside of the CV Shaft before installing the spindle nut but nowhere did it say I has to do that. I am wondering if maybe I should take off the spindle but and grease the CV shaft? The bearing is pre greased but would that make sense?
The above information would be sufficient for a technician to drive the car and experience the symptom, it is not enough to tell you what is wrong without directly investigating it. Potential power steering issues include the drive belt condition/tension, clogged reservoir filter, and even cavitation problems in the system that is addressed by revising the return hose on some cars.
It is not an issue where you need to put grease on the CV shaft, at least that much is for certain.
