Wiper fluid nozzles
I've been search for some info on this without much luck.
The wiper fluid nozzle on my driver's side is only partially working. The top 'hole' which is supposed to squirt fluid onto the upper windshield doesn't seem to work at all, while the lower two just kind of weakly dribble fluid onto the lower part. Passenger side is just fine.
I tried cleaning the nozzles with soapy water and a toothbrush, and also stuck a pin into each hole hoping to clear out any debris but that did not help.
Ordinarily it wouldn't bother me but with winter weather here and road salt, it is kind of important for visibility.
So any suggestions on how to fix this? I wanted to check and make sure the hose leading to the nozzle is OK but I can't seem to figure out how to get to it.
Here's a video on how to do it on a 2011 Sorrento, but I don't know if it's the same---probably similar system.
VIDEO on UNCLOGGING WASHER PUMP
