Lincoln town car - electrical issues
Shorted out the driver side door chime button , now I have no interior lights (dome lights etc) no power door locks, no power mirrors and my keyless entry(key fob) doesn't work. Checked all fuses and there aren't any blown. Is there a relay or something somewhere? Anyone have any ideas? If this is familiar to anyone please let me know.
THIS SITE might have the diagram.
The symbol would look like this:
The single or double lines indicate the duty rating for the fusible link.
The door locks and courtesy lights share several power supplies. Fuses 11 and 17 in the instrument panel fuse block should have power to and through them at all times. Fuse 6 should be hot in accessory or run, and fuse 8 should be hot in the run position.
There is also a 30amp circuit breaker in the under hood fuse block. If those all have correct power to and through them, then testing would have to move to the remote keyless entry module behind the right side of the dash.
So just to recap the current issues:
-no dome light
-wipers don't hide when they're off
-heater won't change to floor setting is stuck on upper vents only
-no power locks
-when I push the driver side door lock button it makes the headlights flash on
-battery went bad seemingly all of the sudden but was most likely at the end of its life
-no power mirrors
-gauges are out of calibration
-keyless entry stopped working along with the dome light, power locks, mirrors etc
-diagnostic port doesn't communicate with testers(just remembered that) although it does seem to spit out codes with the paper clip method, going to attempt to test it later today after I take it to autozone to verify the port doesn't work properly. Seems to me like all these things have to point mainly at one culprit. If any ideas pop up let me know and we'll discuss it, Thanx for any input.
