Are you currently in the market shopping for a new vehicle? A reporter would like to speak with you; please reach out to [email protected] by 10/21 for more details.
Headlights and Interior Lights Flickering
phillyjenniphillyjenni Member Posts: 1
edited February 2017 in Pontiac
I have a 2000 Pontiac Grand Prix and for the past couple days all the lights flicker and then turn off and then come back on. At first it was just the interior lights flickering and then they went to turning off but they don't stay off they do come back on. What is the issue and how do I fix it
Answers
  • PF_FlyerPF_Flyer Pennsylvania Furnace, PAMember Posts: 9,400
    Could be an alternator/battery issue. When does it happen? At startup? After it's been running a while? Only when the temperature outside is colder?
  • imidazol97imidazol97 Crossroads of America I70 & I75 Member Posts: 25,976
    IF all the lights, tail, headlights, dash panel lights, courtesy lights flicker at the same time, I'd have to
    start checking grounds. There are ground cables to the metal of the car besides the one to the engine.
    Loosen each and clean and retighten.
    And I'd consider the battery as well as the alternator.
    A second trail would be the ignition switch itself. The contacts in the actual switch, not the key lock cylinder, have worn on some earlier GM H-body cars and people might get poor contacts that would break with vibration during driving. But, IIRC, the headlights don't go through the ignition switch.
    If only headlights flicker, then look at the headlight switch. The headlights are protected by a circuit
    breaker which will make contact and break when overheated.
