Check Coolant Light
lrh032146
Member Posts: 2
2005 C230 Kompressor 155,000 miles
I get the "check coolant light", add a gallon of coolant, light goes off, within half tank of gas light comes back on...can see no leak on the ground under the car...where is this coolant going? Thanks
Answers
Given that, ray80 is on the right track here.
First thing I'd do is have the cooling system properly "bled" to remove all the air.
If that doesn't solve it, then have the cooling system pressurized and have it examined carefully for leaks under pressure.
If that doesn't reveal anything, keep the system pressurized and then remove the spark plugs one by one. If any of them have coolant on their tips, then you have a bad head gasket---and given the age and mileage of the car, a big decision to make.
