Are you currently in the market shopping for a new vehicle? A reporter would like to speak with you; please reach out to [email protected] by 10/21 for more details.
2003 Vibe AWD. Engine removed and worked on, when installed it wont start, no spark
projectvibe03projectvibe03 Member Posts: 1
edited April 2017 in Pontiac
I bought the car and the engine was leaking oil from about all the major seals and gaskets.
I removed the engine and replaced all the seals and gaskets and then re-installed the engine.
I am able to turn over the engine, the engine is getting fuel and compression for all 4 cylinders is about 130.
I have tried to test spark and nothing.
I so far have checked to make sure all plugs are securely connected and checked all fuses in the engine bay and they are all good.
Would really love some help, I am willing to check anything.
  • Mr_ShiftrightMr_Shiftright Sonoma, CaliforniaMember Posts: 64,482
    You might check the connections to the crankshaft positioning sensor, and the sensor itself. I'd start with a scan tool and see if the CKP code is thrown or not.
