If you made the switch to a hybrid or EV this year and are happy with the savings you're getting on gas costs, a reporter would like to speak with you. Please reach out to [email protected] by 12/5 for more details.
2001 Dodge Neon Heater Stopped Working
ComputerChickComputerChick St. LouisMember Posts: 1
edited May 2017 in Dodge
I have a 2001 Dodge Neon
While taking my son to school the heater stopped working blowing only cold air. Got to work and then drove to get some lunch on the way back it started dinging and thermostat went to H. I got it home took a half day and taking it to a mechanic tomorrow. Any thoughts of what it could be?
  • Mr_ShiftrightMr_Shiftright Sonoma, CaliforniaMember Posts: 64,482
    edited May 2017
    If you lose all your coolant due to overheating or a leak, you won't get any heat out of the heater--since it requires hot coolant to be circulating throughout the system. So I would say you sprung a leak or maybe a head gasket, and once the coolant was drained, there was nothing to circulate but steam, which...doesn't very well. Also might have been a stuck thermostat--which will also cut off coolant circulation and cause an overheat as well.
    Hopefully, no serious damage. Next time, when the gauge goes to Hot, shut the car off and call a tow truck.
