2016 Mazda 3 - Why is the outside temperature reading so inaccurate?
Just got a new 2016 Mazda 3. I am formerly a Volkswagen owner (diesel) and I am accustomed to the VW temperature reading of outside air being pretty accurate. My new Mazda seems way off the actual temperature. Is there some way to set it, or adjust it?
Answers
Another thing you can usually do is manually update the display. Often times this can be as simple as setting the display to a different piece of information and then returning to the ambient temperature, or it may be done by pressing more than one button simultaneously. Check with service information for details. Note: The owners manual might include this and it might not. When all else fails, read instructions.
Any ideas what may cause this? I first noticed it on the way to work this morning when the temp peaked at 57F then slowly started back DOWN again until it hit 40F... but again, the actual outside temperature hasn't gone above 30F today.
I feel like my car is possessed. And 96 is HIGH. Could this be a symptom of another issue? (And YES I read the manual and all it says is "This number here tells you what the temperature is outside" and gives no info on why it might be off except driving too slow.)
