2018 Infiniti Q50 Lease Deals and Prices
MichaellMichaell Moderator Posts: 267,977
edited September 2017 in INFINITI
Ask your 2018 Q50 lease questions here! Get info about prices, money factor, deals, incentives, and payments.
Check out the 2018 Infiniti Q50 here.
«13456734
  • jazzmangjazzmang Member Posts: 14
    Hey guys, do we have numbers for RWD Red Sport at 39/12k?
  • MichaellMichaell Moderator Posts: 267,977
    .00003 and 54%
  • jmcg37xjmcg37x Member Posts: 6
    Do you have numbers for the '18 3.0t Luxe AWD in MN for 12k/39mo?
    .00057 and 54%
  • jfriar52jfriar52 Member Posts: 2
    Can you provide the numbers for AWD Sport & Red Sport for 39mo/10k?
    3.0T Sport AWD - .00008 and 51%
    Red Sport AWD - .00003 and 54%
  • avilar16avilar16 Member Posts: 1
    Do you have the numbers for the 2018 Q50 2.0 LUXE RWD and 2018 Q50 3.0 LUXE RWD (both 10k miles/year in south florida)? Thanks!
    39/10 numbers:
    2.0 LUXE RWD - .00003 and 50%
    3.0 LUXE RWD - .00079 and 56%
  • rxdoga77rxdoga77 Member Posts: 7
    Do you have the numbers for a 2018 Q50 2.0 PURE RWD, Texas?
  • kyfdxkyfdx Moderator Posts: 271,579
    .00027 MF and 49% residual for 39/15
  • foreverfsuforeverfsu Member Posts: 10
    edited August 2017
    Please provide the numbers for RWD Red Sport with 39/10 terms in Georgia.  Thanks!
    .00003 and 55%
  • firedown31firedown31 Member Posts: 12
    Looking for numbers on an AWD red sport 39/15k in 03062. Appreciate it!
    .00003 and 52%
  • echo002echo002 Member Posts: 28
    Hi, wondering if I can get the numbers for the 3.0 AWD in Illinois for August. Thank you!
    39 and considering both 10k & 12k. Thank you!
    One last question - Sport or Premium?
    Premium, though I think they changed the term to Luxe for the 2018's. Guessing they are the same or I could be off the mark.
    2018 Q50 3.0 Luxe AWD
    39/12
    .00057 MF and 54% residual
    Add 1% for 10K/yr
    39/12
    Add 1% for 10K/yr
    Ouch! I was hoping it'd be in the .00003 range. Guess I should look at the 2017 model. I've got an Infiniti lease that ends next month and weighing options...
  • dsingeruncdsingerunc Member Posts: 56
    Looking for MF and residual on 2018 Infiniti Q50 Hybrid Luxe RWD. Located in FL. Assume 39/10 (or whatever best term is). Any info on Infiniti's MSD program? Thank you.
    .00003 and 55%
    With the MF that low, there isn't any room to apply MSDs
  • rephard714rephard714 Member Posts: 6
    Hi Looking for MF and residual on a 2018 Q50 RWD Red Sport. Located in Orange County CA, 92707.
    39/10K
    39/10K
    .00003 MF and 56% residual
  • evansullivan12evansullivan12 Member Posts: 23
    Hi -- looking for MF and residual on 2018 3.0 Sport in New York for 36/15. Thanks!
  • mike1177mike1177 Member Posts: 57
    MF and resudual on Q50 Luxe AWD and Sport AWD in Pittsburgh. 39/12k
    Assuming AWD, .00003 and 50% - those are also the numbers for 39/15, as well.
    Assuming 3.0T for both:
    Luxe - .00009 and 54%
    Sport - .00003 and 52%
    Thanks Michaell. How does that change if I go with the 2.0T on the Luxe AWD?
    .00003 and 48%
    Hi guys!
    Do you know if there is any lease cash or other incentives on the 2018 Luxe 3.0 or 2.0 AWD?
    echo002 said:
    Hi guys!
    No incentive information for Infiniti
  • redlion031redlion031 Member Posts: 18
    Do you have numbers for the '18 3.0t Luxe AWD in new york for 10k/39mo?
    .00009 and 55%
  • panerai31panerai31 Member Posts: 30
    Could you please help provide the numbers for the following trims:
    luxe rwd: 39/10k
    red sport rwd: 39/10k
    los angeles
    luxe rwd: 39/10k
    los angeles
    3.0 Luxe: .00028 MF and 56% residual
    RedSport: .00003 MF and 56% residual
  • pewpewpuppypewpewpuppy Member Posts: 1
    Could you please give the MF and residual for the following in Ohio 10k/39
    2018 q50 redsport 400 AWD
    2018 q50 3.0t LuxE AWD
    RS: .00003 MF and 55% residual
    LUX: .00009 MF and 55% residual
    luxe rwd: 39/10k
    los angeles
    3.0 Luxe: .00028 MF and 56% residual RedSport: .00003 MF and 56% residual
    Thanks so much. How about awd 3.0 luxe 39/10k?
    are the numbers national or does it vary by region?
    panerai31 said:
    luxe rwd: 39/10k
    los angeles
    Subtract 1% from RWD residual
    Infiniti numbers are national
    hi michaell,
    thanks so much for the quick response. am i seeing the mf correctly for the 3.0t luxe?
    for rwd, its .00028, but for the awd version, it's .00009? 39/10k
    lastly, may i ask whats the mf/rv for 2018 q50 silversport in 39/10k?
    panerai31 said:
    hi michaell,
    Correct on the money factors
    .00003 MF and 54% residual
  • robitron1992robitron1992 Member Posts: 3
    Could I please get the RV and MF for 39/15k in South Florida. Q50 RS400
    Thanks in advance!
    Thanks in advance!
    .00003 MF and 53% residual
  • poopspoops Member Posts: 251
    MF and Residual for the '17 and '18 Red Sport 400 AWD in the Chicago area, please. Looking at 36mos/10k miles. Thanks!
    2018: .00003 MF and 55% residual
    2017 discussion is here:
    https://forums.edmunds.com/discussion/43152/infiniti/q50/2017-infiniti-q50-lease-questions#latest
  • hddeucehddeuce Member Posts: 18
    Looking for MF and Residual '17 & '18 base 2.0t pure RWD in SW Florida. Thanks in advance.
    2018 Pure RWD: .00003 MF and 49% residual for 36/15
