This is a toyota engine design error or manufacturing error and toyota of america heatquarters should aware of this problem.
I called toyota to complain about this engine problem and they claimed they had not heard of the engine problem from toyota owners yet. Since my car is over 90K mile, toyota won't even cover my repair cost.
My mechanic told me there are 6 out of 10 camrys will have this engine problem when 50-90K miles.
I am very disappointed with toyota products especially camrys.
Do you have any idea what is the cause?
How did the mechenics saying?
It looks like the Valve Stem Seals damage, if it is a small leak, the Toyota will not admit it even if it is under warrenty. They would tell you it is carbonized valve cause by customer bad maintenance. So you need to find someone else to open engine to clean...
So you will never get reimbursted even under warranty as long as it does leak too much like tap broken...
Someone suggested to use Auto-RX to clean,but I do not believe it?
Any idea???
My mechanic told me there are no possible way to clean them. The engine needs to replace valve stem seals both intake and exhaust sides eventhough exhaust side requires to do work some cases.
Right now, my car is in the shop for a couple of days. Hopefully, my mechanic would say you just need to replace valve stem seals.
Maybe you are feeling better than me. My car is still under warranty, but local Toyota dealor refuse to admit their engine fault, and repair for me.
Any help would would be appreciated.
Happy motoring Bob
I have a '99 Camry LE 4 cylinder and note that the check engine light is on again. I had the problem early on and the dealer replaced a sensor in the exhaust manifold at about 24,000 miles. Light is on at about 58,000 miles. Any ideas, and is it covered by the emissions warranty? The dealer was not overly cooperative in the first place so I'd like some info before I try again.
Any ideas on the problem?
Thanks in advance
It turns out that the bracket holding the power seat switches had two rivets which were not tightly put in, allowing the bracket to rattle. This would be a clear manufacturing defect, and an example of why Kentucky made Camrys are not as well assembled as Japanese made ones.
Anyway, some judicious hammering and gluing, and the seat is quiet, as it should have been from day one.
Incidentally, the whole seat is poorly made, with poor fitting plastic parts and brackets. I would assume the whole car is like that, and thus people who claim Japanese Camrys are quieter and better made are correct.
Best Regards
I know one other 1999Camry owner who got this same letter,but a 2000 Camry owner did not. My mechanic, a good friend, mentioned that the "engine problem" was probably resolved in 2000 cars. He said that they can call it whatever they want(oil gelling) but the reason that a car would experience blue smoke is from oil being in the engine (valve stems?) where it is not suppose to be. He doubts it has anything to do with maintenance and more to do with flaw in engine design. Toyota recommends oil changes every 7500mi or 6mos. under normal operating conditions. I have proof of my maintenance and my car only has 43000 miles! Toyota was of no help they refuse to admit it is their problem but state (as per letter), "for eight years, unlimited mileage, ...we will cover the engine in your Toyota against oil gel related damage with a Customer Support Program."
(Why would they do that if it wasn't a flaw in their engine design????? They think we're stupid!)
IF you lease a 1999 Camry ,TURN IT IN - do not purchase it, you'll always have problems as this is a serious problem!
Though in your case STP works, it may not work for new Camry, for if Valve Stem Seal failed, the blue smoke was so strong in the morning,you think it is on fire. Because too many engine oil went into Combustion chamber. (So for the second start with not too long onee or two hours, will not be so strong)
What is your smoke looks like? Very strong in the morning starting?
I'd like to thank you for your analysis and
advice. Currently, the car still shakes when
breaking hard, but less than a month ago.
It's almost bearable. Interesting don't you think. If the shaking gets worse, I will probably just get the breaks done all over again..this time I'll get new rotors and pads..and I'll demand a warranty.
Thanks Again,
Joseph
The only way to check to see, is by opening up the valve cover and do the whole procedure. It can be somewhat costly, especially if you have a V6
The dealer claims that this is normal. And, is due to metallic dust that builds up and the brake pads.
Just curious what you think ? The dealer claims that I received new brakes before I purchased the car.
Any other Camry owners have super squeaky brakes ? Is that normal, as the dealer claims ?
thanks.
I have now driven several other 2002 Camrys and I am convinced that this is a factory defect. Every one of them rattle to some extent!
valve adjustment - while it is an occasional maintenance items on these engines, I would not bother unless the valves have become really noisy. if you cannot be the judge of this, take it to a Toyota dealer - they will tell you if it needs doing. And $400 is too much - try $200. or less.
Rust: warranty for rust-through is 5 years/60K miles. But it has to be rust-through, not just surface rust. This is a little unusual on a trunk lid on such a new car - has the paint been damaged in that area by an accident or something? If it is still under bumper-to-bumper (3/36) I would go bug the dealer about it.
Was your radio on? Your buzzing sound may be coming from your radio. Old cars used to have this problem with non-resistor spark plugs. The electro-magnetic emission from the sparks caused buzzing on the radio (especially AM). Although you say the noise goes away once you re-accelerate. So, this may not be the cause. Hope you find your problem.
The morning dew causes a slight rust buildup on the rotor surface, the first initial braking will squeak as it cleans the rotors of the rust.
#1024:
I'd start looking at the electronic components of the distributor. In your case, check the ignition coil and pickup assembly when the car is hot. Checking it while it's cold most likely will not reproduce the problems (this happened on my 84 Corolla....specifically asked him to check the car when it's hot...and he sucessfully reproduced the problem)
I have the same problem. The service people seem to ignore it. I bought a new Subaru Forrester and it has smaller engine but it is smoother than the Toyota Camry 2000 V6. I paid Top Dollars for the Camry V6. This issue of pedal vibrating has been there for a long time. I kept on thinking it will go away eventually ... may be the Camry V6 engine is breaking in or something. I have 33,000 miles now and the Dealership/Service people still have not responded and resolved it. They keep on going through tire rotation and other drills before addressing the problem.
Regards
rishi
I have a camry LE 99. Can anyone help me to explain this:
I have my camry full tank of gasoline and the gas indicator shown that this morning. While I am on the way to work, I saw the gas indicator suddenly drop to half and then slowly it moved up to normal level.
Is this an indicator of any malfunction and do I need any inspection?
James
Thanks for your help. I'm going to call the dealer and see if they'll do anything. I've actually only owned the car for two weeks so hopefully they'll cover the repairs. By chance do you know the TSB numbers that may be applicable?
Thanks again.
How would you then open the filler door?
Anyway to get it from the trunk??
James
I'm also considering a Honda accord wagon or a Subaru (certainly easier to find), as second preferences. Anyone have an opinion?
I think it is going to take a number of people coming forward and demanding repair on this to get them to do anything. I am going to try to start a discussion thread to gather the owners who have rattles together. Thanks for your input. My email is mbergman@kc.rr.com if you have additional info. PLEASE OTHER OWNERS WITH THIS PROBLEM CONTACT ME. Go in and make them fix it!!
Camry wagon: it might be fairly hard to find a 4-cyl wagon? Not many were sold around where I live. The V-6 is not the same as the problematic truck engine - it is the same as the old Cressida engine that was also in some Supras as the base engine - it is a very reliable engine overall.
the 3.0L truck engine was the 3VZ-E (SOHC, and had the head gasket problems) and the Camry V6 was the 3VZ-FE.
The 3.4L truck engine was the 5VZ-FE...all the VZ motors are iron blocks.
