Brake part missing in 09 Altima sedan
Recently I got the rotors resurfaced and brake pads changed in my 2009 Altima 2.5 SL from Raleigh Tire. Just after the job was done, I test drove the car and it drove well with adequate braking power. After a few days, I was checking the tire pressures when I found something protruding out from the brake caliper of the driver side front wheel. Fortunately, that part is not touching the rim yet, so the wheel is rotating smoothly and I never came to know about it until I accidentally noticed while checking tire pressure. The passenger side front wheel/brake is fine. Below I have included pictures of both sides.
Nobody has touched the car since the brake job. It has only been driven (very sanely) and it is driving and braking well. It seems a pin is missing and I suspect the Raleigh Tire mechanic messed this up when working on the brakes. Is it possible to purchase only the pin and fix this or do I need to change the entire caliper? Any other suggestion is most welcome. Thanks in advance.
Driver side front:
http://i66.tinypic.com/fmnaq0.jpg
http://i68.tinypic.com/10s4y09.jpg
Passenger side front:
http://i288.photobucket.com/albums/ll181/bb700092/PassengerFront1.jpg
http://i64.tinypic.com/vxjlhu.jpg
Driver side front:
Can you put these photos on your computer and upload them right here using that little "mountain" icon you see above the text box? (or if you can put them on a host with a URL address).
Driver side front:
You can see the anchor pin where the wear sensor should be attached to the back of the pad. There are a couple possibilities, one is that the pads are mis-installed and the wear indicator that is "missing" might be on the bottom of the pad that is on the inside of the rotor. You might look to see if there is a wear indicator at the bottom of the pads. If so then they are reversed in that caliper. Another likely explanation is that the shop sources discounted pads and they don't always have all of the new and appropriate hardware, so the wear sensor might not be attached to any of the pads.
Then there is the profit side of the equation. The labor fee's alone are not sufficient to generate the profits that are needed to operate the business successfully. Missing profit from the parts sales impacts the shops ability to provide training and tooling. Other poor management practices along with allowing carry in parts impacts the level of the technician that they can hire (reflected in wages and benefits) and retain and so you end up with a situation like this where everything around the technician is wrong and somehow they are always supposed to get it right. Ultimately this ended up with you getting an improper repair this time which IMO is exactly where it should end up. Absolutely, but they aren't alone in that. The question remains if they are going to learn from it. They didn't generate the kind of profit that the job should have returned and now they get to deal with a warranty issue and a dissatisfied customer. The tech will learn from the mistake, and ultimately realize everything else that is wrong about his/her situation and will eventually move on leaving a hole to be filled by someone else who has yet to learn these same lessons. Or I might be right and the pads you supplied from Amazon didn't come with all of the appropriate hardware as well.
I changed the pads on both front wheels using the same brake pads purchased from amazon at the same time. It is not the case that one pad didn't come with hardware while the other did. So whatever hardware they came with, after installation, both the wheels should look identical. But from my pictures, you can see they are not identical. That is why I think Raleigh Tire messed up.
