I have a 2000 Mitsubishi Montero with a strange problem. The AC compressor works when the cabin fan is set to 1,2 or 3 but the fan won't work. I can tell the compressor is on because cold air seeps out. When I turn the fan to setting 4 it starts blowing but the compressor turns off. Click the fan back to setting 1,2, or 3 and the fan turns off but the compressor turns back on. Any clue what could be happening?
Did you find any solution for this problem...? I have the same issue with my 1998 Mitsubishi Montero. Please let me know.
I have 2001 Mitsubishi Montero LTD, few month ago appeared problem with engine. I have to start engine for 2 or 3 times. When is running on position „P“ and you push gas pedal the engine is speeds up easily. But when you change the gear to the „D“ the engine starts shake up and runs sometimes not on all 6 cylinders. Then you drive and even if you floor it the engine will not rev up over 2500 rpm. At „P“ can rev up to red pole without any problems.
I checked the fuel pump and cleaned it, I cleaned the injectors too. I tested the injectors, and they are working not equally but working. And after clean up it is still doing. Can anybody have similar experiences? Can anybody help, Thank you very much.
Any suggestions? I guess to find out if valves are ruiner or not, still have to do the change for about 650.00 before a compression check can be performed.
On top of that, I have two other FORDs that went out. different probs. Time to go for Honda or Toyota but they are so expensive. then again ...hmmm?
Having this same issue today for first time 6/6/2019. I have a 2001 Mit Montero Ltd full size. Admittedly I dont drive it much anymore cause of the breaks every time I crank it up, but im keeping this baby going to be a classic one day lol.
Anyway, Sunroof not working. Passenger front window and door lock not working- all others are, interior lights not coming on, utility screen above radio not powering on, AC comes on and blows lightly, but not changing with the controls so fan stopped working. Checked fuses and find nothing blown. Read something about the BCM Body Control module being a possible culprit, but I looked on ebay at that part and it physically reads on the part itself that it controls other things that I am not having trouble with. Anyone have duplicate problem and find a fix? Thank you for any help or suggestions.
